Blown headgaskets - Mustang Evolution
Old 08-19-2012, 04:47 PM   #1
Rooster22's Avatar
Blown headgaskets
So I bought my mustang v6 not even a month got stranded in traffic while it was over heating and blown my head gaskets. Thinking about just bringing it to the dealership and saying I'm not paying for this lemon anymore bc they don't wanna cover it. Any thoughts
Rooster22 is offline   Reply With Quote
Old 08-19-2012, 06:03 PM   #2
maldog's Avatar
Region: Nevada
Re: Blown headgaskets
Go park it on your day off in front of their dealership with a sign on say " They sold me a lemon "
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-19-2012, 08:13 PM   #3
08Mustang's Avatar
You positive it's a blown head gasket??
08Mustang is offline   Reply With Quote
Old 08-19-2012, 09:43 PM   #4
Blogger
99ford's Avatar
that's exactly the right thing to do.
[QUOTE="08Mustang"{
You positive it's a blown head gasket??[/QUOTE]
+1
Old 08-20-2012, 02:57 PM   #5
Wmcgrattan's Avatar
Build a sleeper an drop a 5.0 in it
Wmcgrattan is offline   Reply With Quote
Old 08-20-2012, 08:10 PM   #6
08Mustang's Avatar
Yeah don't waste that much time and money
Old 08-22-2012, 11:55 AM   #7
Rooster22's Avatar
Yes I'm sure blowing out white smoke and there's water in my oil
Old 08-23-2012, 10:57 AM   #8
05MUSTANG4.0L's Avatar
Something like this happened to me but it turned out the upper and bottom thermostat housing broke
05MUSTANG4.0L is offline   Reply With Quote
Old 08-25-2012, 07:50 AM   #9
Blogger
99ford's Avatar
Thats a head gasket if I've ever seen one.
Old 08-26-2012, 09:01 AM   #10
08Mustang's Avatar
Same here
Old 08-26-2012, 09:18 AM   #11
Ive seen the intake crack and leak coolant into the cylinder and cause the same systom..It was the 4.2 though,,but we done alot of them at work
---------- Post added at 09:18 AM ---------- Previous post was at 09:16 AM ----------
Head gasket will sometimes blow water out of the radiator cap too,,due to compression gases,,is it doing that too??The only way to know for sure is do a air leak test
mymustang is offline   Reply With Quote
Old 08-26-2012, 11:59 AM   #12
Rooster22's Avatar
It blew water out the radiator after I changed my thermostat but it think that was bc I over filled my coolant
Old 08-26-2012, 01:04 PM   #13
Rooster22's Avatar
And there's water in my oil so I pretty much know it's a head gasket
Old 08-26-2012, 03:07 PM   #14
if you have to do it yourself,,do a airleak test first ,,its not hard to do,,look it up on line and you can prob find a video..The 4.2 i was talking about had the same symptom..I acually found it while i was taking the intake off to remove the heads,,replace the intake and gaskets and it was fine..after that we prob had 10 of them with the same problem,,most were just the intake gaskets..But if ur letting ford do it they will figure it out for ya..good luck,,and sorry it happened
Old 08-26-2012, 07:59 PM   #15
Originally Posted by 08Mustang
Same here
My happened to break on a day that snowed in houston, and its only snowed twice in the past ten years here
Old 08-27-2012, 10:45 AM   #16
Rooster22's Avatar
I tried to look on line for how to do that test idk im looking at the right though
Old 09-01-2012, 07:03 AM   #17
irishnite41's Avatar
Region: New Hampshire
Same here
Me too
irishnite41 is offline   Reply With Quote
Old 09-01-2012, 12:46 PM   #18
Do you mean the air leak test..You pull all the plugs,,take your compression hose that you screw in the cylinder,,remove the schrader valve out of the compression hose,,screw in the hose in the cylinder,,apply about 50psi of air,,but first make sure the piston is at the bottom of the suspect cylinder and the valves are closed,,you shouldnt hear any air,,if you hear air from the cylinder next to it then its the head gasket,,If it passes the test i would figure the intake leaking..If your not comfortable doing it i would just let ford make the call,,
Old 09-01-2012, 03:41 PM   #19
Rooster22's Avatar
They finally agreed to fixing it after some major *** chewing but I thank all of you guys for the help
05:31 PM
