Oil change on jack or ramp - Mustang Evolution
Old 09-06-2012, 11:15 AM   #1
Blakhwk's Avatar
So I usually change my oil using the jack and stands, I was thinking of getting a ramp so I don't have to jack the car and save some time.
my questions is, using a jack or a ramp, will this affect the oil change process, I mean if the car is not flat while changing the oil, will this affect anything, or it's ok for the car to be jacked or ramped while doing this, or maybe jack it on one side better than the other side?
Visca Barça
Blakhwk is offline   Reply With Quote
Old 09-06-2012, 11:31 AM   #2
Adogg's Avatar
I change my oil on ramps its alot easier wont make any difference as long as u get the car on the ramps correctly. Just one thing in my mustang i have two drain bolts and if u do also the one in the back is going to have most of the oil and the front one will only have a little
Don't hate....... appreciate
Old 09-06-2012, 06:06 PM   #3
I've always used jacks and jack stands and never had a problem with the oil draining properly. Well, with the exception of my Ranger, it was tall enough and I'm skinny enough to fit under it without jacks.
sixty4half is offline   Reply With Quote
Old 09-07-2012, 08:44 AM   #4
Blakhwk's Avatar
Yes I'm planing to get a ramp, it's much easier than jacking up the car!
I'm not sure if I got two! I'll check the next time I change the oil.
Thanks
---------- Post added at 09:44 AM ---------- Previous post was at 09:40 AM ----------
Dude I'm looking to buy a Ranger, I found a 98 sport with 120k on it, hopefully it's still available!
Visca Barça
Old 09-07-2012, 09:54 AM   #5
Mine had over 200k when I sold it. I just don't have the tools to do a brake job or change out the clutch. It had some electrical problems I wasn't willing to spend the time or money to trace and fix either so it was just easier to sell it, but the engine still ran great.
Old 09-08-2012, 09:16 PM   #6
Rogue Slider's Avatar
The ramp would be better.
Rogue Slider is offline   Reply With Quote
Old 09-09-2012, 10:16 AM   #7
Blakhwk's Avatar
This is what I'm planning to get, just waiting for my next oil change to get it.
Visca Barça
Old 09-09-2012, 10:51 AM   #8
DaBluedude's Avatar
I've got a set of rhino jack stands and they're awesome. Make life so easy. Slide under and done.
2003 Mach 1
Old 09-12-2012, 02:30 PM   #9
kirpy's Avatar
Re: Oil change on jack or ramp
Id get a set of the plastic ramps. They grip alot better and dont slide while driving ip them.
kirpy is offline   Reply With Quote
Old 09-14-2012, 06:29 AM   #10
Blakhwk's Avatar
I found this rhino set for 49.99
I think it's a good price!
Visca Barça
Old 09-14-2012, 07:02 AM   #11
kirpy's Avatar
Yeah thats about what i paid.
Old 09-15-2012, 11:47 AM   #12
SCCofSV's Avatar
Some may think, over kill. I like to think of it as "Living Insurance!" First and Foremost, I live in Southern California. Earthquake Capital! So, I rarely pull into my driveway, I back in. With that in mind, I prefer my metal ramps. But, I have to use bricks to drive up on those. Which I do. Secondly, our home is on a slope, as is our driveway. Because of that, I must use Jack stands to even out my car. Oh! I must not forget my trusty Rubber Wheel Chock! Work's for me!
SCCofSV is offline   Reply With Quote
Old 09-18-2012, 06:21 AM   #13
jamin22786's Avatar
Region: Iowa
Mine can't make the incline of ramps, to close to the ground with the front lip.
jamin22786 is offline   Reply With Quote
Old 09-18-2012, 06:15 PM   #14
SCCofSV's Avatar
Know what you mean, I have to drive up onto a couple red clay bricks first then I can make it up the ramp.
Old 09-18-2012, 06:24 PM   #15
jamin22786's Avatar
Region: Iowa
Mine's not that incredibly low, but I've got to put it on jacks just to get the lift arms under it!
Old 09-18-2012, 07:00 PM   #16
Blakhwk's Avatar
So if I don't have a front lip, do you think I should be good?
Visca Barça
Old 09-18-2012, 07:13 PM   #17
Blakhwk's Avatar
Look what I found here, DIY ramps, I think it's good only if you have enough space in your garage!
http://www.mustangworld.com/ourpics/...amps/index.htm
Visca Barça
Old 09-19-2012, 08:31 AM   #18
I used to change oil myself....now I am old and retired....Ford will do an a. Works OLF and tire rotation for $30.00...I don't mess with it anymore.
Xring3 is offline   Reply With Quote
Old 09-19-2012, 08:37 AM   #19
Blakhwk's Avatar
I know what you mean, for me I like to do it at my free time, I enjoy do stuff to the car.
Visca Barça
12:04 AM
