twin turbo manifolds - Mustang Evolution
Old 09-30-2012, 07:41 PM   #1
kirpy's Avatar
Does anyone know if anyone makes a twin turbo manifolds for the 4.0 v6
kirpy is offline   Reply With Quote
Old 09-30-2012, 11:22 PM   #2
Probably not, the 4.0 is one of the hardest mustang engines to find parts for.
Old 10-01-2012, 06:26 AM   #3
xhgwx's Avatar
http://www.on3performance.com/ThreeV6.aspx
U don't need TT on a v6 one is enough
xhgwx is offline   Reply With Quote
Old 10-01-2012, 07:34 AM   #4
jamin22786's Avatar
Region: Iowa
In confused, looks like a gt kit?
jamin22786 is offline   Reply With Quote
Old 10-01-2012, 07:37 AM   #5
xhgwx's Avatar
It's the v6 kit, of u have any doubts about fitment call them.
Old 10-01-2012, 07:38 AM   #6
jamin22786's Avatar
Region: Iowa
How much does it cost?
Old 10-01-2012, 07:42 AM   #7
xhgwx's Avatar
Full kit is just over 2k I think
---------- Post added at 08:42 AM ---------- Previous post was at 08:42 AM ----------
Click buy now at the bottom and takes u to a page to see price
Old 10-01-2012, 08:27 AM   #8
kirpy's Avatar
1900$. Ive seen rhe kit. Its a great price. I just wanted twin turbos
Old 10-01-2012, 08:32 AM   #9
Las0mbra's Avatar
Unless you have a seriously built engine and wanting 600+ HP, a single turbo will work great.
Old 10-01-2012, 08:36 AM   #10
kirpy's Avatar
Im going to build a 2nd engine and shooting for 600+.
Old 10-01-2012, 08:45 AM   #11
Las0mbra's Avatar
Realistically? Building a v6 is expensive and you really don't get the performance per dollar than you would with a V8.
Even then, a good single turbo can support well over 600hp.
For twin I don't know what to tell you. Unless the manifolds are custom fabricated, I've never seen a set of them.
Old 10-01-2012, 08:54 AM   #12
xhgwx's Avatar
U won't need a twin for even 600.
Twins are unneeded
Old 10-01-2012, 09:01 AM   #13
Las0mbra's Avatar
Twins are unneeded
+1
I was just saying unless he wanted 600+HP, it's not even kind of worth it to have twins.
Old 10-01-2012, 11:35 AM   #14
kirpy's Avatar
To build the engine its going to cost roughly 10k. I bought the car for under 5k. So dollar per dollar id have the same amount into the car i can get a GT for. So the build is going to cost less then a GT. And i just want to do twins for the hell of it.
Old 10-01-2012, 11:44 AM   #15
jamin22786's Avatar
Region: Iowa
I can understand that, try to be the top 4.0 and beat almost all gt. You will have to have it custom made though...
Old 10-01-2012, 12:08 PM   #16
If you want twins go for it. The problem that everyone is talking about. If you have twins (which isn't necessary) you are probably gonna have some serious lag. Where a single turbo will spool much easier creating power faster. So I would atleast use smaller turbos to help with that problem. Because its possible you won't even make any more power than you would with a single turbo unless done right. You gotta think you will basically only be having 3 cylinders driving each turbo.
Old 10-01-2012, 02:30 PM   #17
kirpy's Avatar
Very true. Im planning on running 20lbs of boost. So i was thinking a small turbo then a medium sized turbo. And if i do all new internals itll handle it.
Old 10-01-2012, 05:49 PM   #18
jamin22786's Avatar
Region: Iowa
You'll have to do the same turbo on each side
Old 10-01-2012, 05:51 PM   #19
kirpy's Avatar
Why would i have to do the same on each side?
Old 10-01-2012, 06:00 PM   #20
To keep your engine balanced. You would be loading more on one side then the other.
Old 10-01-2012, 06:24 PM   #21
kirpy's Avatar
How can you use the same setup on other v6s? Smaller turbo on 1 side and medium on the other.
Old 10-02-2012, 07:24 AM   #22
jamin22786's Avatar
Region: Iowa
On all modern v6 you'd have to use the same turbo on both sides in a twin turbo application.
11:43 AM
