Top Motor Lubrication? - Mustang Evolution
Old 10-04-2012, 04:34 PM   #1
Blogger
99ford's Avatar
Is it possible to lube the top motor? And would anyone know how to do it?
Old 10-04-2012, 05:55 PM   #2
Region: Montana
I have not heard of this terminology in quite a while. In the past Marvel Mystery Oil or Bardahl were added to the fuel to achieve this. Marvel may still say this on the bottle.
Back in 70 or so, I knew an automotive engineer that used STP for this but I cringed as it was thick as elephant snot!
I do believe that an occasional or frequent use of MMO is beneficial. It has been good by me.
"OLD AGE AND TREACHERY WILL OVERCOME YOUTH AND SKILL"
manicrodder is offline   Reply With Quote
Old 10-04-2012, 07:54 PM   #3
Blogger
99ford's Avatar
Sorry, I should've said the convertible top. Haha my brain wasn't even thinking
Old 10-04-2012, 08:07 PM   #4
Region: Montana
That's cool. Brought back some good memories!
Old 10-04-2012, 08:30 PM   #5
Blogger
99ford's Avatar
Haha when you said marvel mystery oil I thought hmm never heard of that stuff, but it sounds like something out of 60s/70s
Old 10-04-2012, 09:03 PM   #6
Region: Montana
It came into existence in 1923 and still going!
Old 10-04-2012, 09:26 PM   #7
Convertible top motor?
Or the top of your engine?
Using MMO in your fuel will lube the top of your engine.
The top being the valves and anything your fuel runs through.
Old 10-05-2012, 05:00 AM   #8
Blogger
99ford's Avatar
Convertible top motor.
Old 10-05-2012, 06:30 PM   #9
I doubt there is any way to lube the motor itself.
If it is not a ball bearing motor, it probably uses self lubricating bushings and they may be worn out.
I'd try to find an exploded view of the motor and see what it uses for sure.
Old 10-06-2012, 07:15 PM   #10
Blogger
99ford's Avatar
Ok I found out from a Ford tech in training that there is a way. Once I get to it I'll post the steps.
Old 10-06-2012, 07:41 PM   #11
I'd like to see that.
Old 10-06-2012, 07:52 PM   #12
Lorraine's driver
ab_mach1's Avatar
TH, what's MMO? Additive?
Instagram: @ab_mach1
Old 10-06-2012, 09:09 PM   #13
Blogger
99ford's Avatar
Marvel Mystery oil
Old 10-06-2012, 10:02 PM   #14
Lorraine's driver
ab_mach1's Avatar
Marvel Mystery oil
I've never heard of that stuff. Is it good?
Old 10-07-2012, 09:41 AM   #15
Blogger
99ford's Avatar
I didn't know about it either until they started talking about haha
Old 10-07-2012, 10:53 AM   #16
Marvel Mystery oil
I suppose it is alright. I have used it on a few engines over the years, but I never saw any "miraculous" results.
Old 10-07-2012, 12:24 PM   #17
Blogger
99ford's Avatar
Hmm..
Oh and I ran across this post- Convertible Top Motor/Pump Fluid Flush/Refill FYI POST double checking a few things the procedure is a bit different on the 05-09 from the looks of it.
Still haven't done it yet hopefully next weekend.
Old 10-07-2012, 12:46 PM   #18
Lorraine's driver
ab_mach1's Avatar
If it does as it says (minus the miracle), its perfect for the 4.6L. You can hear all the clicking action going on in there. Does Lucas make something like this?
Old 10-07-2012, 05:10 PM   #19
Region: Montana
It does what it says it will do by my experience. It probably is not as dramatic in synthetic oil as conventional but a great fuel additive none the less. Why not replace your fuel injector cleaner with MMO next time and see for yourself?
Old 10-07-2012, 06:06 PM   #20
Lorraine's driver
ab_mach1's Avatar
I'm seriously thinking about it. Right now, I put in Lucas injector cleaner about once a month. I think I'll give MMO a try.
Old 10-08-2012, 02:04 AM   #21
I'm not 100% sure if Lucas does or not, but I'd almost be willing to bet that they do have something similar.
10:09 AM
