Rattling - Mustang Evolution
Old 10-05-2012, 02:51 PM   #1
Claypops's Avatar
Rattling
There is a squeaky rattling noise coming from my front end when I hit bumps or drive on a bumpy road. Any ideas what it is? Ball joint?
Claypops is offline   Reply With Quote
Old 10-07-2012, 11:12 AM   #2
jamin22786's Avatar
Region: Iowa
Are you lowered? Do you have castor plates?
jamin22786 is offline   Reply With Quote
Old 10-07-2012, 02:48 PM   #3
Claypops's Avatar
No it's stock suspension and plates
Old 10-07-2012, 04:12 PM   #4
jamin22786's Avatar
Region: Iowa
Could be a lot of things, my guess is shock/strut assembly. How many miles on the stock setup?
Old 10-07-2012, 04:13 PM   #5
Blogger
99ford's Avatar
Inside the car or outside the car?
Old 10-07-2012, 04:57 PM   #6
Claypops's Avatar
I have 111k on the car right now. And it's coming from the outside.
Old 10-07-2012, 05:01 PM   #7
jamin22786's Avatar
Region: Iowa
I'd take it to a suspension specialist to be sure, but that's my thought. I'm no mechanic, but I know they shouldn't last that long.
Old 10-07-2012, 08:46 PM   #8
Claypops's Avatar
Oh really? Ok thanks. I will have them look at it. I was just hoping it was something small that I could fix at home
Old 10-07-2012, 10:11 PM   #9
jamin22786's Avatar
Region: Iowa
You could fix that yourself, not too tough, but no need spending the money unless you're sure that's the problem
Old 10-10-2012, 10:55 AM   #10
05MUSTANG4.0L's Avatar
I have 125000 on mine and it didn't rattle just yet but I know it will soon bc this shop was trying to trick me into buying both front tire rod ends.... My grandpa is a mechanic and he was going to change them for me but noticed that the rubber boot was all tore up and I didn't need then replaced after all... Are they good on yours?
05MUSTANG4.0L is offline   Reply With Quote
Old 10-10-2012, 02:21 PM   #11
Claypops's Avatar
Is this the rubber boot your talking about?
ID:	71759   Click image for larger version
Old 10-11-2012, 09:43 AM   #12
EXACTLY MY friend,i took both of them off and noticed that one them was perfect and the other one was starting to go out so I went to all the auto parts store possible and found out that nobody makes it just for the mustang my only option was to buy a universal pair for $6 plus a $5 heavy duty grease. The reason for it was bc when I trolled twirled the tire rod ends it felt like sand bc of the rubber boots letting all the dirt flow into it. All u do is clean it with the coffee stirrer that comes with any wd-40 spray can and blue all the dirt out
Old 10-11-2012, 02:28 PM   #13
Claypops's Avatar
Ok cool. Thanks a lot.
Old 10-11-2012, 02:55 PM   #14
No problem just make sure u know how to check if a rod is good or not
Old 10-11-2012, 05:19 PM   #15
Claypops's Avatar
So I have to replace the boot?
Old 10-12-2012, 09:44 AM   #16
Yeah.... And since your down there I would clean the t rod ends with wd40 & put the boots with lots of h.duty grease
Old 10-15-2012, 12:33 PM   #17
Did u every fix the problem?
Old 10-15-2012, 02:25 PM   #18
Claypops's Avatar
No I ended up working this weekend so I haven't had the chance to fix it yet.
Old 10-15-2012, 02:59 PM   #19
StangRebel's Avatar
I got the same issue going on with mine, good to know im not alone haha
StangRebel is offline   Reply With Quote
Old 10-15-2012, 05:02 PM   #20
Claypops's Avatar
Ya man. It's been doing it for a while I just never knew what it was.
06:49 PM
