tokico d-spec strut and shock kit - Mustang Evolution
Old 10-08-2012, 02:23 PM   #1
jamin22786's Avatar
Region: Iowa
Anybody have experience with these? Do they change castor/ camber?
jamin22786 is offline   Reply With Quote
Old 10-08-2012, 03:58 PM   #2
kickerofdoom's Avatar
They shouldnt change it. But I would look into spring if you get them
Old 10-08-2012, 04:04 PM   #3
jamin22786's Avatar
Region: Iowa
I have frpp lowering springs and castor bolts on now. I can afford these or castor plates to fix ride issues and strut assembly noise.
Old 10-09-2012, 08:11 AM   #4
jamin22786's Avatar
Region: Iowa
What would be a better buy for ride quality, struts or plates/panhard?
Without plates/panhard do you see any potential issues?
Thanks guys!
Old 10-09-2012, 08:14 AM   #5
DaBluedude's Avatar
Imo. Go with bilistien or koni yellow over the d spec. Unless you got a reallllly good deal on them.
2003 Mach 1
Old 10-09-2012, 08:25 AM   #6
jamin22786's Avatar
Region: Iowa
Bilstein hd cost $848, Koni str.t are $408, tokico d-spec are $599, eibach pro-damper are $440. I liked the tokico because they are adjustable and 35 out of 35 people give them 5 stars
Old 10-09-2012, 08:34 AM   #7
jamin22786's Avatar
Region: Iowa
Frpp struts are $590 and supposedly require the Shelby mount upgrade
Old 10-09-2012, 09:00 AM   #8
Lorraine's driver
ab_mach1's Avatar
+1 I've heard people say they wish they had purchased ^ instead of the d spec. Said for the money, they thought they'd be better.
Instagram: @ab_mach1
Old 10-09-2012, 11:23 AM   #9
jamin22786's Avatar
Region: Iowa
So you guys think the koni str would be the way to go? What with the lack of adjustment?
Old 10-10-2012, 02:41 AM   #10
DaBluedude's Avatar
I had the eibach pro kit and liked them a lot but they don't feel as high quality as the bilistien stuff. I also like the koni yellows and they have a life time warranty which I've seen a buddy evoke a couple times (one valve failure and one that he broke by curbing the car haha) both bilistien cars I've worked on have been bulletproof and seem to handle awesome. Tociko does make pretty decent non adjustable shocks but the adjustable ones I see fail often. The car im thinking about is a 08gt and since the suspension swap in 2010 he's had to replace 3 shocks and 1 strut. All d-spec stuff. I'd say if you have to do adjustable, get the konis over the d-spec. If your after good shocks I would look at bilistien then eibach. I'd pay 250$ easily over a cheaper package. If you can get matched springs with your struts do it. Or just take the plunge and go coil over.
2003 Mach 1
Old 10-12-2012, 08:50 PM   #11
dolfin13's Avatar
How much did u lower your car? Check out americanmuscle.com their project car 2005 , it tells you exactly what to get
dolfin13 is offline   Reply With Quote
Old 10-12-2012, 11:13 PM   #12
jamin22786's Avatar
Region: Iowa
dolfin13: only about an inch, FRPP N springs. AM doesn't really address the pinion angle change, just the caster/camber angle change.
DaBlueDude: Thanks for the help! I hate buying crappy parts more than about anything. Do you know a place to get the yellows? are they adjustable?
Old 10-13-2012, 02:14 AM   #13
DaBluedude's Avatar
The konis? I've seen the before but the car that had them bought them through a local performance shop. Honestly, if you aren't married to the adjustable id get the bilistien kit!
2003 Mach 1
03:39 PM
