Exhaust - Mustang Evolution
Old 10-08-2012, 08:59 PM   #1
Wmcgrattan's Avatar
Exhaust
Can you run your car with out any mufflers or does it mess up ur sensors ? I have dual exhaust but a muffler shop ****ed up my pypes mufflers an I can't find my magnaflow mufflers so is it possible I need a answer ASAP
Wmcgrattan is offline   Reply With Quote
Old 10-08-2012, 09:41 PM   #2
03torch's Avatar
I'm pretty sure if you removed just mufflers you would be fine
03torch is offline   Reply With Quote
Old 10-08-2012, 09:53 PM   #3
Wmcgrattan's Avatar
Yeah I should be ok right ? It won't mess with the ecu or o2 sensors ?
Old 10-08-2012, 10:44 PM   #4
jamin22786's Avatar
Region: Iowa
You are talking about running straight pipes back, not just running with pipes only part of the way out, right?
jamin22786 is offline   Reply With Quote
Old 10-08-2012, 11:03 PM   #5
You should be fine with just straight pipes, unless you are taking out the cats, then you will start to throw codes. However the 4.0 sounds terrible with straight pipes... Your choice though
Old 10-09-2012, 07:43 AM   #6
Wmcgrattan's Avatar
No I completely agree but the shop I toke my car to switch my mufflers ( cause I had magnaflow an I was switching to pypes ) an they thought I was a good idea to hit the muffler with a hammer an **** them all up an now I can't find my magnaflows ... Fml!
---------- Post added at 08:43 AM ---------- Previous post was at 08:41 AM ----------
I'm talking about everything but the mufflers only stock cats an everything will stay
Old 10-09-2012, 08:06 AM   #7
jamin22786's Avatar
Region: Iowa
You will have to make sure you take strait pipes from your mid pipe out, otherwise you run into fire dangers.
Old 10-10-2012, 08:38 AM   #8
Wmcgrattan's Avatar
Fire dangers?
Old 10-10-2012, 09:39 AM   #9
jamin22786's Avatar
Region: Iowa
If your exhaust only goes through to the end of your midpipe (nothing for axel back) then the heat coming out of your midpipe could be enough to melt plastic and even start a fire. It nothing else, you would have to have a tip put on turning the exhaust towards the ground (grass burner).
Old 10-12-2012, 04:17 PM   #10
Saucywalnuts's Avatar
Also when it's cold out the exhaust will engulf you car.
Saucywalnuts is offline   Reply With Quote
exhaust
12:05 PM
