Brake upgrade - Mustang Evolution
Old 10-09-2012, 02:49 PM   #1
JBillone's Avatar
Question Brake upgrade
I was surfing local kijiji and saw this ad selling 2005 gt front take-offs for $100:
"Take offs may only have been on the car for 10 klms. rotors , pads, calipers, flex lines, and brackets. rotor alone is worth over a hundred bucks"
Pictures look alright. Is this all I would need to upgrade? Is it worth it? Stock rims on my 2005 v6 were 16", I bought a set of 17" summer rims and tires last year. Are my winter tires and rims a problem?
Thanks!
JBillone is offline   Reply With Quote
Old 10-09-2012, 09:47 PM   #2
JimC's Avatar
You have to use the 17" wheel at a minimum. The 16" won't clear the caliper and larger rotor.
All you need to do is swap the rotors and the bracket on the caliper. The caliper itself is the same size, just the bracket is different to move it out to clear the rotor.
And the rear is exactly the same so don't bother getting the GT rear set up.
JimC is offline   Reply With Quote
Old 10-12-2012, 05:00 PM   #3
JBillone's Avatar
Perfect! I'm still undecided because I'll end up having to get new rims and rubber for winter (16's). Thanks for the info!
Old 10-13-2012, 06:08 PM   #4
JimC's Avatar
Maybe your post isn't clear. You won't be able to use a 16" wheel with the GT front brakes on the car. You have to use the 17" wheels. So if you put winter tires on your 16" wheels they can only go on the back; front won't fit that wheel.
Old 10-20-2012, 07:44 AM   #5
Blogger
99ford's Avatar
Yeah I have the GT upgrade kit on mine the rotors are larger and take the 17inch to clear. 18 would be best to give you the most room
---------- Post added at 09:44 AM ---------- Previous post was at 09:43 AM ----------
I like the kit and notice an increase in stopping power.
Old 10-23-2012, 06:32 AM   #6
SCCofSV's Avatar
I have 20 9.5 wheels, I've always wanted to know if I could upgrade to GT brakes. Do you know if they"ll fit mine as well?
SCCofSV is offline   Reply With Quote
Old 10-23-2012, 06:41 AM   #7
alrefire's Avatar
Without a doubt!!
You need at least 18 in wheels
You've got 20!!!!
Old 10-23-2012, 07:13 AM   #8
alrefire's Avatar
*17
Old 10-23-2012, 03:51 PM   #9
Blogger
99ford's Avatar
Originally Posted by alrefire
Without a doubt!!
You've got 20!!!!
+1 yeah I bought the kit from AM. But as long as you have 17+ it will work
---------- Post added at 05:51 PM ---------- Previous post was at 05:49 PM ----------
Oh and the calipers are the same!
Old 10-27-2012, 11:37 AM   #10
SCCofSV's Avatar
Thanks so much! These are what I'm getting:
OEM Item ID:
Front Rotors: 4R3Z1125BAFront
Calipers: 4R3Z2B120-1A
DMS complete description:*
Rotor Front Mustang 05-10 GT 12 1/2 R/L*
Calipers Front Mustang 05-10 R/L Pair with Pads and Supports.
$149.00
It sounds like a great deal, is it?
Old 10-27-2012, 12:09 PM   #11
Mkolabin's Avatar
I'm new to the game in some regards but to my eye at least that looks like an almost impossibly good deal.
Where is it so I can snipe you? LOL
2006 V6 - Black on black. Tints, Louvers, Shorty Antenna and BBK CAI. "We're just getting started folks!"
Mkolabin is offline   Reply With Quote
Old 10-27-2012, 05:57 PM   #12
Blogger
99ford's Avatar
Yeah the rotors alone are about $120
http://www.americanmuscle.com/mustan...kits-0510.html
Old 10-27-2012, 10:05 PM   #13
Atrav83's Avatar
Not if you go go eBay, I got slotted and drilled with high performance pads for 120
Atrav83 is offline   Reply With Quote
Old 10-28-2012, 08:20 PM   #14
Blogger
99ford's Avatar
Yeah the rotors right? She's talking like only $20-30 for the calipers to. Which seems a little cheap to me
Old 10-29-2012, 07:41 AM   #15
Mkolabin's Avatar
I thought so...
Old 10-29-2012, 08:25 AM   #16
Atrav83's Avatar
I'm talking rotors and pads
Old 10-29-2012, 08:38 AM   #17
Blogger
99ford's Avatar
That's within reason, but I'd still be concerned about the quality.
SSCofSV Mentioned hers was $39 more than yours with calipers which seems a little cheap to me
---------- Post added at 10:38 AM ---------- Previous post was at 10:34 AM ----------
OEM Item ID:
$149.00
NVM NVM that's NTO the one thing with NTO just flush out the calipers with fluid and grease the pistons real good!
Old 10-29-2012, 10:51 AM   #18
Atrav83's Avatar
They're the exact same brand that all the big name stores sell
09:21 PM
