Can ya help me out?? - Mustang Evolution
Old 10-19-2012, 08:56 PM   #1
Here's a video of my car. As soon as I start it up it hesitates for like a second. Any ideas??
http://youtu.be/l-L1pVXKk74
Old 10-20-2012, 09:49 AM   #2
Old 10-20-2012, 10:42 AM   #3
Rogue Slider's Avatar
This might not help but hey it's worth a try. Have you tried the idle reset?
Rogue Slider is offline   Reply With Quote
Old 10-20-2012, 11:39 AM   #4
Don't know how I'd go about that. Tips?? Lol
Old 10-20-2012, 11:50 AM   #5
I think I'm being picky. It's probably just from sitting overnight
Old 10-20-2012, 11:53 AM   #6
This is how
Old 10-20-2012, 12:07 PM   #7
Blogger
99ford's Avatar
Yeah maybe try that.
Old 10-20-2012, 01:29 PM   #8
That the like serious way to do it?? Lol ill have to do it after work
Old 10-20-2012, 09:38 PM   #9
Blogger
99ford's Avatar
Haha, doesn't sound like it to me, but worth a try!
Old 10-20-2012, 10:25 PM   #10
When I was putting in my CAI the other day I did the idle reset and you can tell the difference
Old 10-21-2012, 03:11 AM   #11
It says let idle till gets to temperature. That mean let the temp needle get where it's supposed to be or just let it get down to it normal idle after starting it?
Old 10-21-2012, 02:22 PM   #12
Just let it go to normal temp. I just let it idle for a little bit while I did something else then it was at normal driving temp when I got back in
Old 10-21-2012, 02:30 PM   #13
ok, noted. im gonna do this as i get off work
Old 10-21-2012, 03:18 PM   #14
Cool let us know the results. I also noticed that the car didn't crank right up after doing this so be aware
Old 10-21-2012, 03:32 PM   #15
its all good, i work at a parts store. that means professional right?? haha i crack me up
Old 10-21-2012, 04:40 PM   #16
After I drive it for ten miles can I drive it more or do I need to kill it after ten miles
Old 10-21-2012, 04:46 PM   #17
LAS97GT's Avatar
Try this next time:
-Turn the key to start, do not start.
-Turn the key off.
-Turn the key to start again, this time crank the engine. Does it crank right up? Bet it does. Guess you know what that means. I am having same problem only worse. Pending a 255 LPH fuel pump to keep up with my aftermarkets. It did it before upgrades, now just worse.
---Las97GT
Old 10-21-2012, 04:47 PM   #18
It always cranks right up just right after I start it there's a very quick hesitation that's been getting on my nerves lol
Old 10-21-2012, 07:47 PM   #19
Blogger
99ford's Avatar
Have you scanned it for any codes or checked theTSB?
Old 10-21-2012, 08:22 PM   #20
It's not throwing a code. What TSB
Old 10-21-2012, 09:53 PM   #21
Blogger
99ford's Avatar
I thought there was one out there for it.. Let me look in the AM.
Old 10-21-2012, 10:44 PM   #22
Panhead_77's Avatar
I've done a few mods on my car and I started getting that same hesitation. Three weeks later my battery was no longer holding a charge. Have your battery tested. Most like not your alternator as mine was fine. You may be coming up on a bad battery. Is it TW stock battery that came with the car originally? I have 45k on my car an just replaced the battery today. Just a thought and its free to get tested at auto zone
Panhead_77 is offline   Reply With Quote
Old 10-21-2012, 10:51 PM   #23
I work at a parts store. I changed the battery a year ago, optima red top
Old 10-21-2012, 10:57 PM   #24
Panhead_77's Avatar
Good choice. As a mechanic I'd say with the battery not being an issue just have your idle reset.
Old 10-21-2012, 11:05 PM   #25
I did the reset mentioned above a few posts & ill find out in the morning how it worked and post back up here tomorrow
Old 10-22-2012, 09:02 AM   #26
It didn't hesitate this morning!
Old 10-22-2012, 10:29 AM   #27
Cool !!!!!!!!
Old 10-22-2012, 11:31 AM   #28
I was pumped! Lol
Old 10-23-2012, 02:22 PM   #29
Blogger
99ford's Avatar
That's good to know! I dont have any of these issues but if I do I am going to utilize this!
Old 10-24-2012, 04:45 PM   #30
LAS97GT's Avatar
This is how
Interesting. How come this solved the problem?
---Las97GT
Old 10-24-2012, 05:18 PM   #31
LAS97GT's Avatar
I take it that your meaning of hesitation means a drop in idle. You ECU Controls that. Your idle control motor attached may be the culprit, sticking during the Dashpot drop. Remove it and clean. Also clean any vacuum operated device. It's not a fix, it a trouble shoot that may save you money.
---------- Post added at 07:17 PM ---------- Previous post was at 07:12 PM ----------
Just read the post, hesitation stopped. There is a solidly true saying; can't make horse power without electricity. Good luck. And congrats to the fella/ gal that posted that piece. I'll drop it in my kit bag for future use.
---------- Post added at 07:18 PM ---------- Previous post was at 07:17 PM ----------
Yeah, good work rougue slider.
---Las97GT
10:40 AM
