Running Lean - Mustang Evolution
Old 10-21-2012, 08:42 PM   #1
Joe_Roma5's Avatar
Running Lean
I bought a "no tune required" cai from AM about 3 months ago and just recently my check engine light came on. I had it diagnosed and apparently I am running lean. Any ideas how to fix this?
'06 4.0 V6 custom x pipes, cai, screamin demon coil pack, 10mm live wires spark plug wires, NGK iridium plugs, 93 octane bama tune
Joe_Roma5 is offline   Reply With Quote
Old 10-22-2012, 01:33 AM   #2
Rogue Slider's Avatar
Call AM and see what they say. I've seen here on the forum that they are really helpful.
Rogue Slider is offline   Reply With Quote
Old 10-22-2012, 07:38 AM   #3
do you ever hear marbles bouncing around (detonation) check your plugs for signs of the white part being messed up (busted up/missing). That can be a sign of detonation.
If your 05-09 has never had the plugs done they CAN Break off so FYI research that before you try to pop them out.
Old 10-26-2012, 01:05 PM   #4
Joe_Roma5's Avatar
well i asked AM and they said, will all the info given, that it coulld have been just a fluke since i had replaced my battery and that the computer might have rebooted and just needed to familiarize itself with the cai and dual exhaust. thank god for technology heehee
Old 10-26-2012, 10:01 PM   #5
That's good news. While putting on the CAI did you do a idle reset?
Old 10-27-2012, 06:21 AM   #6
Joe_Roma5's Avatar
would i really need to with a no tune required intake? and if so, how would i go about doing an idle reset?
Old 10-27-2012, 06:43 AM   #7
Dako1994's Avatar
Yeah you need to do the idle reset since the CAI takes in more air than the ECM is programmed to withstand without throwing the lean codes compared to the stock intake. To do the idle reset, unplug the negative cord on the battery and let the car sit for a while. Some say let is sit for 5 minutes and others say for a few hours, just preference I guess. But after that time, hook the negative cord back up to the battery and start the car with all accessories off (radio, A/C, lights, etc) and let the engine reach full operating temperature. After it has reached the temperature, let the car sit at idle for 1 minute with all the accessories off. Then let the car idle for 1 minutes with the A/C on max. After that take the car for at least a 10 mile drive if not longer so that the ECM can relearn your driving habits and then your good to go! If you need to double check while doing it, it tells you how to do it in your owner's manual in the section about changing your battery. Hope this helps
Dako1994 is offline   Reply With Quote
Old 10-28-2012, 10:16 AM   #8
dolfin13's Avatar
Mine also did that but then i got the tuner. Now it dosent come on anymore. When i had called am on the issue. They told me they advertise what the manufacturer says. I was pissed. But i was gonna get the tuner anyway. So it worked out
---------- Post added at 10:16 AM ---------- Previous post was at 10:14 AM ----------
I tried that a couple times with mine it didnt work
dolfin13 is offline   Reply With Quote
Old 10-31-2012, 12:13 AM   #9
Joe_Roma5's Avatar
Meh. I'll probably just sell it and go buy a tune required cai and tuner combo.
Old 11-01-2012, 01:24 AM   #10
Joe I think you can still put a tune on a non tune required CAI. The BBK CAI that I have is a non tune CAI but you can put a tune on it.
Old 11-02-2012, 06:52 PM   #11
dolfin13's Avatar
I bought the bbk cai also it said didnt need a tune, but it did, now my check engine light dosent come on
Old 11-02-2012, 10:22 PM   #12
I did the idle reset after I installed mine. That way the computer would learn the new intake
Old 11-02-2012, 10:31 PM   #13
Lorraine's driver
ab_mach1's Avatar
Idle Re-Learn
Disconnect NEG from battery for 30min
Reconnect and start car, let idle as eng gets to operating temp. Let it idle a little over a minute
Turn on A/C to MAX, let idle little over a minute, turn off A/C
Then drive the car for at least 10 miles
Instagram: @ab_mach1
12:07 PM
