when should i change my transmission oil? - Mustang Evolution
Old 10-29-2012, 10:08 PM   #1
I jusy hit 41k should i change it?? How can you check it
Andy714 is offline   Reply With Quote
Old 10-29-2012, 10:12 PM   #2
1slosix's Avatar
i usually stick to the 50k mile mark of most major fluid changes (like a rear flush and fill and trans fluid swap)
although i missed that mark on my current stang and just hit 57k..im holding off till spring on mine because i'm doing a jmod.
btw for checking it...if its an auto sadly you don't get a dipstick (thanks ford)..
as for actually changing it. if it's a 5 speed at least in my old GT ('04) the easiest way to fill it was by pull the shifter out and pouring into the top of the trans. i don't know if s197s can do the same
carving corners like a boss
Old 10-30-2012, 07:26 AM   #3
Mkolabin's Avatar
This, I would like to know.
How to do on my 06 manual tranny.
Suppose my Chiltons Guide will say...
2006 V6 - Black on black. Tints, Louvers, Shorty Antenna and BBK CAI. "We're just getting started folks!"
Mkolabin is offline   Reply With Quote
Old 10-30-2012, 07:52 AM   #4
Lorraine's driver
ab_mach1's Avatar
My car had 34,xxx miles on it when I bought it this past February. The first thing I did was change all the fluids over to synthetic. I used Royal Purple for the engine (5W-20) and rear diff (75W-90). I tried Royal Purple Synchromax but the tranny synchros did not like it and made it hard to shift, so I switched to Mobil 1 ATF (one of the fluids recommended). The primary recommendation is Dexron III/Mercon Non-Synthetic ATF.
Other member should chime in if you have an auto tranny.
Instagram: @ab_mach1
Old 10-30-2012, 08:49 AM   #5
There's a bolt you take out and stick your finger In lol on the tranny itself
Old 10-30-2012, 08:51 AM   #6
Mkolabin's Avatar
For reals yo?
I get to finger my Stang?!
Old 10-30-2012, 08:55 AM   #7
For reals yo?
If that's the way ya want it, yes you do!
Old 10-30-2012, 11:05 PM   #8
What about for automatics?? Should i wait till 50k to change it
Old 10-31-2012, 04:36 AM   #9
I almost didnt buy mine because of the dipstick issue,,I think thats crazy,,but you can get a pan with a dipstick on the 05 06 models,,I think from AM
---------- Post added at 04:36 AM ---------- Previous post was at 04:32 AM ----------
If your just doing a filter and refill,,I would do it now,,If you drive her hard I would change the fluid around 30000,,your only taking out about 5,, 6 quarts,,so I would change it more often,,
mymustang is offline   Reply With Quote
01:43 AM
