How To Clean CAI - Mustang Evolution
Old 11-06-2012, 07:05 PM   #1
Claypops's Avatar
How To Clean CAI
I have a JLT cai and someone have me a k&n cai cleaning kit. Can I use it? I'm assuming it works the same way I just want to make sure. If not, how should I clean it?
Claypops is offline   Reply With Quote
Old 11-06-2012, 07:06 PM   #2
Venomouz831's Avatar
I cleaned my bbk filter with just water
)02 Gt, Founder of WE2G
Old 11-06-2012, 07:11 PM   #3
Claypops's Avatar
Ok. I was told by a friend to stay away from water but I don't see how it could hurt it. Thanks.
Old 11-06-2012, 07:17 PM   #4
It didn't hurt mine just dry it really good, I did mine with my gf hair drier
Old 11-06-2012, 08:42 PM   #5
phobik's Avatar
Aren't you suppose to oil it? How can water just do the trick?
phobik is offline   Reply With Quote
Old 11-06-2012, 11:07 PM   #6
Oil helps catch the small particles.
mustbstangin is offline   Reply With Quote
Old 11-06-2012, 11:08 PM   #7
I didn't, just took the filter out and rinsed it and let it dry
Old 11-06-2012, 11:58 PM   #8
It's not me, it's you.
primer2tone's Avatar
Too much oil will ruin the maf sensor.
Old 11-07-2012, 12:53 AM   #9
Rogue Slider's Avatar
Someone told me to use water and let it dry then spray it with WD-40
Rogue Slider is offline   Reply With Quote
Old 11-07-2012, 12:57 AM   #10
Humm, I wouldn't use WD40. Personally, I don't clean mine. I toss em out and get a new one. But I know a lot of people like to get the most from their money.
Old 11-07-2012, 02:56 AM   #11
The kit ain't but 12$ @ my nearest store for the k&n cleaner. I spray mine from inside out with low pressure water hose, let it dry then oil it & let it set all night. Put her back in in the AM
Old 11-07-2012, 03:05 AM   #12
I guess another reason why I just replace mine is due to the salty climate I live in on the coastline. The filter gets rust pits on the mesh, which is also one of the reasons why I painted my heat shield and intake tube.
I do have a "drop in" K&N in my F-150 and I do use the recharge kit for that bugger.
Old 11-07-2012, 03:36 AM   #13
Good reasoning
Old 11-07-2012, 01:58 PM   #14
phobik's Avatar
This is what I have. Ur telling my I can just water that intake to clean it, dry it and put it back on??
Old 11-07-2012, 01:59 PM   #15
phobik's Avatar
It's JLT Btw
Old 11-07-2012, 02:02 PM   #16
It's JLT Btw
The filter yes take it off. It should be reusable and washable
Old 11-07-2012, 03:12 PM   #17
Atrav83's Avatar
Us K&N filter cleaner I use it on mine and it work perfectly
Atrav83 is offline   Reply With Quote
Old 11-07-2012, 03:58 PM   #18
phobik's Avatar
Does that cleaner involve oil? Where did u get it and for how much? Mine right now looks a bit dirty but I want to do it the fastest way.
Old 11-07-2012, 04:02 PM   #19
gqsmash's Avatar
Hit up the zone for the kit
gqsmash is offline   Reply With Quote
Old 11-08-2012, 02:10 PM   #20
Blogger
99ford's Avatar
+1 plus K&N wouldn't put their name on it if it was bad.
Advance or Autozone should have them. Even O'Reilly's.
Old 11-08-2012, 04:24 PM   #21
SCCofSV's Avatar
Yes, K & N uses a Air Filter Oil (Step 2). It comes in a 6.5oz aerosol can that you spray on the after the filter has been thoroughly cleanse (rinsed) and air dried. It is also the last step in cleaning your JLT air filter.
(Step 1) 12oz Cleaner comes in a pump bottle that is sprayed on the inside as well as on the outside of the filter completely saturating it. You allow it to soak 10 minutes, then rinse it with cold water. Depending on how dirty it was, you may need to do this process twice.
It's important to let your filter AIR DRY NATURALLY and completely before appling the oil. I always clean my filter at night that way it can dry while I am sleeping and in the morning I spray the filter! They K&N say to allow the oil to wick I say allow to soak oe penetrate the cotton filter.
At K&N High Performance Air Filters, Air Intakes, & Oil Filters it runs $13.46
JLT has a new product, S&B Precision II: Cleaning and Oil Kit. It is actually less then K&N Cost per volume, I mean. It runs $29.00 but you get enough for 3 - 4 filter cleanings 32oz bottle and their filter oil. their product, actually the spray bottle of cleaner is no longer a pump but is now a trigger spray making it a thousand times better to spray and/or use.
You can check out their website ar JLT PERFORMANCE, Home of the JLT TRUE COLD AIR KIT. And There You Have It! I didn't intend for this to be so long!
SCCofSV is offline   Reply With Quote
Old 11-09-2012, 01:43 PM   #22
This is some good info. My BBK filter is blue. I've heard the K&N cleaning kit has a red spray is this true because I like the blue filter that I have now and don't want it turning red.
Old 11-09-2012, 01:49 PM   #23
Mustang32Bill's Avatar
Afe has blue spray
Mustang32Bill is offline   Reply With Quote
Old 11-09-2012, 02:30 PM   #24
contact Jay at JLT and double check that the K&N recharge kit will work for the S&B filters they sell.
I just purchased a new filter for 35 bucks due to recharging them gets a ton of oil everywhere. If you recharge it clean the maf after 200 or so miles (say a week) then again two weeks later and maybe one more time a month later. That gunk can mess up stuff.
Old 11-09-2012, 03:07 PM   #25
So I can really just clean it with soap and water
Old 11-09-2012, 03:16 PM   #26
Just use water
Old 11-09-2012, 03:32 PM   #27
Cool
Old 11-09-2012, 03:45 PM   #28
Atrav83's Avatar
You really should use K&N, don't go cheap just cuz it costs more money, you want good out of the car you gotta put good in it
Old 11-09-2012, 05:20 PM   #29
It's not that I'm trying to go cheap. I'm trying to find the best way to keep it clean. This is my daily driver and I only have 1 car so if I use something and spray it onto my CAI and it messed up the engine I'm screwed I'm sure Ford won't cover any repairs needed
Old 11-09-2012, 06:09 PM   #30
Atrav83's Avatar
The K&N is made for CAI filters, and ford wouldn't cover aftermarket stuff either way, I'm just saying it works the best in my opinion, and I don't really see how water would help cuz it can't catch the small particles you really need to clean out
Old 11-10-2012, 08:18 PM   #31
SCCofSV's Avatar
I have used K&N on my JLT CAI for the past 5 years only because I haven't found an Auto Parts Store that carries the JLT CAI CLEANER!
I have also have never experienced any mess with spraying the oil on my filter either! I Make sure I spray close to the filter (perhaps 2"- 3") away. I have the long filter and I start with spaying the oil inside the filter then spray each pleat starting at the bottom (big end) because I hold it by the rubber opening. When I finish, I'll check for light areas that I didn't spray enough on. When Im finished, I will stand it up on the big end or large opening. I then let it rest or sit like that for about 20 minutes so it can soak up the oior wick process. I will also wipe all the rubber areas down to remove excess oil. Oh! My oil filter is Red!
Old 11-10-2012, 08:27 PM   #32
Hahahahaha mine is blue
Old 11-10-2012, 09:02 PM   #33
08SteedaQ350's Avatar
That's nice and clean engine bay.
---------- Post added at 10:02 PM ---------- Previous post was at 10:01 PM ----------
+1+1+1+1
08SteedaQ350 is offline   Reply With Quote
Old 11-11-2012, 02:50 AM   #34
SCCofSV's Avatar
Just follow the instruction that came with the product. If you don't have them, I do and will be happy to upload it. Or you can go to: Jlttruecoldair.com
As I said earier, I think, if not I say it now. If you have a JLT CAI and are you are concerned about using another brand cleaner or perhaps they aren't compatible? Well, I have been using both products together and have had wonderful results.
No! Water alone can not clean the filter. You need something that breaks down the oil but won't harm the cotton fibers of the filter!
It won't be "Red"! It Will Be Purple
No, you can not use soap on it. You have to use the enclosed cleaning solution that breaks down the oil or degreaser (If you will) that came with it. And the water is only used to rinse all that crud.
<Laughing> Oppsss!!! Meant to say, my "airfilter" is red, not my oil filter, that's purple! And that would be the color of your filter if you used K&N CAI Recharger (Red oil) I believe the cleaner is clear. I can't tell you for sure because it is in my garage and its late and my rollup doors make too much noise.
Old 11-11-2012, 02:16 PM   #35
I guess I will have to swallow my blue pride hahahahaha and use the K&N cleaning kit.
cai
04:00 PM
