Tire Alignment - Mustang Evolution
Old 11-16-2012, 08:45 AM   #1
Joe_Roma5's Avatar
Tire Alignment
I have recently noticed that my two front tires are at a certain angle. The top of each tire is slightly pointed inward. One person tells me I should take it to the shop to have everything adjusted on my front end and another person says its perfectly fine, and the car was built that way for cornering. Please help, very confused!
'06 4.0 V6 custom x pipes, cai, screamin demon coil pack, 10mm live wires spark plug wires, NGK iridium plugs, 93 octane bama tune
Joe_Roma5 is offline   Reply With Quote
Old 11-16-2012, 08:59 AM   #2
Lorraine's driver
ab_mach1's Avatar
Has it been lowered?
Instagram: @ab_mach1
Old 11-16-2012, 09:01 AM   #3
Joe_Roma5's Avatar
No, sir. Stock suspension.
Old 11-16-2012, 09:31 AM   #4
It's not me, it's you.
primer2tone's Avatar
If you wanna pay to have your alignment checked, you could do that. Are you seeing any wear on the inside tread of the tires? If not, then it's fine.
Old 11-16-2012, 09:51 AM   #5
Joe_Roma5's Avatar
Tires are fairly new, had them for only a few months, so if there is any wear, it is very minimal. I did however, notice some vibration in the steering wheel when braking at high speeds (70+) but there is no pull to the left or right while braking.
Old 11-16-2012, 10:02 AM   #6
some places check aligment for free~ just be there when they do and get a printout vs hearing them just tell you 'it needs it'
know the stock range of each area and ensure it does need it, if so get it done.
Old 12-28-2012, 11:03 AM   #7
pamson's Avatar
sounds like the wheel camber has been altered. Setting the camber either positive or negitive does change how the car corners, but when most of your driving isn't going around in circles it will wear your tires out faster.Race car mechanics do this to aid in more tire contact on the road in corners but they are not concerned how long the tires last. With the top of the tire leaning in just keep an eye on tire wear more promanant on the inside of the tire. If no great differance your are ok.
pamson is offline   Reply With Quote
01:02 PM
