The EV6 injectors should work I don't believe they reverted back to the old EV1's for the newer sixers, and even the injectors from a new 2013 5.0 are only 32.8 psi at normal pressure, you'll have to look into some from a termi if you want stockish manufactured injectors, they're rated at 39/42lbs which should be plenty enough, check out corral.net they have a great classifieds section and usually a couple sets float around there, next bet would be eBay or amazon
SSM S3 heads, P&P lower, comp 218/226 cam, 4.2 bottom end, 3k stall, flow 40's, O/R x-pipe, Pacesetter lt's, SCT xcal2 (93 Ortizperformance tune), Windstar upper, 65mm tb, CAI, FRPP T-lok, 3.73's, SFC's, cut factory springs, KYB shocks/struts, MM LCA's
Sponsored by Ortiz Performance, great tunes at a good price!
