need some help - Mustang Evolution
Old 12-19-2012, 11:27 AM   #1
Atrav83's Avatar
need some help
So I just traded with a guy on the forums for rims and tires. Really Long story short when I got back on the road the wheel was going crazy like I needed a balance, which I'm going to get this weekend, and there was one balded tired that seemed it was put on wrong because it said "inside" on it. Also two tires in the front are the same while the two tires in the back are not, I was thinking of matching the rear tires and leaving the fronts as they have almost new tread. Any help would be greatly appreciated.
Atrav83 is offline   Reply With Quote
Old 12-20-2012, 02:24 AM   #2
Rogue Slider's Avatar
Make sure the rear tires get balanced and have good tread on them because of the RWD. The tires with the most tread on them should also go on the rear.
Rogue Slider is offline   Reply With Quote
Old 12-20-2012, 03:57 AM   #3
Atrav83's Avatar
Gotcha, thank you!
Old 12-20-2012, 01:05 PM   #4
Glad to help
Old 12-20-2012, 01:28 PM   #5
post up some pics too
Old 12-22-2012, 11:11 PM   #6
Atrav83's Avatar
Ok so I got my new tire and it balanced, but the wheel stool shakes sometimes, any one help me on this??
Old 12-23-2012, 08:09 AM   #7
What is happening? & which tires are doing it?
Old 12-23-2012, 08:20 AM   #8
Atrav83's Avatar
It feels like the front tires are shaking the faster I go because the wheel shakes the faster I go
Old 12-23-2012, 08:55 AM   #9
you got an alignment right?
Old 12-23-2012, 08:58 AM   #10
Atrav83's Avatar
Only a front end one cuz they said that's all id need
Old 12-23-2012, 09:12 AM   #11
faster you go the more it shakes? shake more with using the brakes?
Old 12-23-2012, 09:17 AM   #12
tc x 4's Avatar
Sounds like you got ripped off by buying a bent wheel.
Old 12-23-2012, 09:19 AM   #13
Atrav83's Avatar
Yes sir
---------- Post added at 11:19 AM ---------- Previous post was at 11:19 AM ----------
Damn really??
Old 12-23-2012, 09:23 AM   #14
tc x 4's Avatar
Originally Posted by Atrav83
Yes sir
Damn really??
The problem never existed before the wheels rite ?
Old 12-23-2012, 09:24 AM   #15
Atrav83's Avatar
The guy I got them from didn't have any shaking like I do
Old 12-23-2012, 09:56 AM   #16
tc x 4's Avatar
Of course he didn't, he was selling.
Old 12-23-2012, 10:04 AM   #17
Atrav83's Avatar
Well I'm going back to the shop now so well see wat happens, thanks guys and I'll keep you posted
Old 12-23-2012, 11:04 AM   #18
This may be a redundant question, but did you put the wheels on right?
Old 12-23-2012, 11:12 AM   #19
Atrav83's Avatar
Positive lol and I took it to a shop
Old 12-23-2012, 03:05 PM   #20
JimC's Avatar
Are these aftermarket wheels? If so, did you remove the little clips on the studs? Aftermarket wheels will shimmy because the little clip doesn't let them sit flat - you don't need it because it is only there to hold the rotor on during assembly. Ford wheels have a recess that the clip goes into so you don't get the shimmy.
JimC is offline   Reply With Quote
Old 12-23-2012, 03:10 PM   #21
JimC's Avatar
You can see the clip on the stud at 1:00 in this picture. Just a little piece of metal that you can pull off
Old 12-23-2012, 03:15 PM   #22
Atrav83's Avatar
Yes they are, and where is the little clip??
---------- Post added at 05:15 PM ---------- Previous post was at 05:14 PM ----------
Oh the clip on the brakes? Would that really do much?
Old 12-23-2012, 04:28 PM   #23
Since the clip doesn't let the wheel lay flat then yes it could create the shaking you are talking about. Take the wheels off, and use something like a flat head screwdriver to get the clips off.
Old 12-23-2012, 04:38 PM   #24
Atrav83's Avatar
Would the pads hold on without it??
Old 12-23-2012, 05:02 PM   #25
Different clip you are thinking of. As long as your brakes are secured properly they should be fine.
---------- Post added at 04:02 PM ---------- Previous post was at 03:58 PM ----------
skip to 2:35
Old 12-23-2012, 05:04 PM   #26
JimC's Avatar
No not the clip on the caliper. The clip on the stud for the lug nut at 1:00 - look at the rotor hat. Ignore the brake calipers and pads.
Notice the 5 studs for the lug nuts (at 1:00, 4:00, 6:00, 8:00 and 11:00), only one has a clip on it? The one at 1:00. It looks almost like a washer on the stud. That is what you have to remove so that your wheel lies flat against the rotor hat.
Old 12-23-2012, 05:08 PM   #27
Originally Posted by JimC View Post
No not the clip on the caliper. The clip on the stud for the lug nut at 1:00 - look at the rotor hat. Ignore the brake calipers and pads. Notice that on the 5 studs for the lug nuts, only one has a clip on it? That is what you have to remove so that your wheel lies flat against the rotor hat.
That vid i posted shows which clip to take off, it is kinda hard to see in the pic.
Old 12-23-2012, 05:09 PM   #28
Atrav83's Avatar
Do I need to have the wheel off?
Old 12-23-2012, 05:11 PM   #29
I don't want to sound like a ******, but obviously you need to take the wheel off lol.
Old 12-23-2012, 05:13 PM   #30
Atrav83's Avatar
Then you shouldn't have said anything cuz you did make an *** out of yourself, its pouring down rain in Cali all week and I need my car to drive right, which is why I was asking if its possible to do it with the wheels on.
Old 12-23-2012, 05:18 PM   #31
*** of myself? I'm in Cali also, and i can see the rain, but that had nothing to do with the problem at hand, which we were trying to help out with. The clip is behind the wheel on the rotor, there is no way to take off the clip without taking off the wheel. If you would actually think about it a little then you wouldn't need to ask that question. If you need to drive your car tonight then don't take off the wheels tonight and fix the problem some other time. Simple as that.
Old 12-23-2012, 05:26 PM   #32
Atrav83's Avatar
I didn't realize it was on the rotor *** hole, which is why I asked, listen soccer I don't like you bro so just stay the **** off my posts and I'll stay off yours. Thanks and happy holidays
---------- Post added at 07:26 PM ---------- Previous post was at 07:25 PM ----------
Thank you very much sir! You were very helpful as usual and I'll handle the clip when the rain stops! How's that 2013 treating you?
Old 12-23-2012, 05:28 PM   #33
ForsakenProto's Avatar
Settle down boys, you got an answer, end of story. No reason to try and act all high and mighty on the Internet
ForsakenProto is offline   Reply With Quote
Old 12-23-2012, 05:28 PM   #34
If you didn't realize that it was on the rotor then you should have said something... Obviously the picture and the video didn't show it clearly enough. But fine, i'll leave. No sweat off my back, one less person to worry about.
Old 12-23-2012, 05:32 PM   #35
davidcseifert's Avatar
Region: Arkansas
it was posted twice and you couldn't see the clip? lol
no need to blow up about it..
blower/new cam soon
02:29 PM
