Problems/Need inputs - Mustang Evolution
Old 01-01-2013, 04:39 PM   #1
sixxerstang's Avatar
So my car, 2005, sat at the dealership prettyyyyy long and not sure if it was treated properly before hand. Little flaws show up, too much to really go through. Is it normal for a car to have several little flaws after sitting so long at a dealership?
sixxerstang is offline   Reply With Quote
Old 01-01-2013, 04:50 PM   #2
roushcoyotepony's Avatar
So your car is used and also sat at a dealer? Cuz my 2005 was purchased new in 2006 after sitting at a dealer and had a ding, scratches on the door handle, and bad swirl marks. So I'd say stuff like that is normal but just not sure what flaws yours has.
roushcoyotepony is offline   Reply With Quote
Old 01-01-2013, 04:53 PM   #3
Mine isn't appearance issues. :/ We've replaced and fixed most stuff but it's little things like things with acceleration, when I put it in park sometimes it takes a sec to actually do it, my belt squealed but im sure its because it got wet. Its raining. But just little things that mostly just happen on an old car are happening on mine. Im just a little confused why the flaws dont work themselves out or why they keep popping up.
Old 01-01-2013, 05:03 PM   #4
Just my 2 cents, the 2005s were the first year for this style mustang and there were more recalls and tsbs than other years. Ive had a LOT of warranty work on mine but afterwards the problems were resolved. The only one I still have is the gas tank fill up issue. Good luck finding fixes for yours!
---------- Post added at 07:03 PM ---------- Previous post was at 07:02 PM ----------
Oh and ps my auto transmission is quite slow going into gear when cold but is ok otherwise. I think it could just use another fluid flush as the last one improved the operation immensely
Old 01-01-2013, 05:09 PM   #5
I have a gas tank problem too. But something is stuck in mine. Ha. But yeah, mine was a test car apparently. Made in January of 05. But Im doing everything I can to keep it. I love this car too much to get rid of it, even if that means dealing with the problems.
Old 01-01-2013, 05:29 PM   #6
I know exactly what you mean! Even after a wreck I've always got mine working well again! Best of luck again and you should post a pic of your baby!
Old 01-01-2013, 05:31 PM   #7
I will. Thanks!
Old 01-01-2013, 10:52 PM   #8
Blogger
99ford's Avatar
Yeah that's common my brother works for a Chrysler dealership and they wash the cars with a pressure washer and plain water, no soap, then dry them all with same chamois.
Old 01-02-2013, 01:50 AM   #9
Rogue Slider's Avatar
The gas tank problem can be solved by turning the handle 90 degrees when putting gas in. When a car has been sitting on the lot for a long period of time you should get all your fluids changed, unless you have documented that it has been done recently. If you've gotten a car fax the last fluid change will be listed.
Rogue Slider is offline   Reply With Quote
Old 01-02-2013, 09:22 AM   #10
Oh wow..
---------- Post added at 11:22 AM ---------- Previous post was at 11:22 AM ----------
Ok, thanks.
04:40 AM
