HiD Kit - Mustang Evolution
Old 01-02-2013, 02:49 AM   #1
Cali_JC's Avatar
HiD Kit
I'm thinking of purchasing an HID kit type H13 , anyone may help me and tell me is this a perfect match. Basically a plug it in and done type of labor. Thank you in advance for all of your help. Here below is the link in which I am referring.
http://bit.ly/U8Hbe3
Cali_JC is offline   Reply With Quote
Old 01-02-2013, 09:50 AM   #2
1slosix's Avatar
Go to ddmtuning.com and order your kit there...great price...great warranty.... great product
carving corners like a boss
Old 01-02-2013, 11:41 AM   #3
Cali_JC's Avatar
I don't want to spend that much money due to other projects/mods I have in mind. That being said the eBay ones won't due?
Old 01-02-2013, 12:16 PM   #4
1slosix's Avatar
they are the same price as the DDM ones so if it was me i'd stick to the ones i know work great. as for projector upgrades be sure to get projectors designed to work with HIDs...if you don't the output will be horrible
Old 01-02-2013, 01:27 PM   #5
Cali_JC's Avatar
So what specifications are for the mustang 06 4.0 ? I'd greatly appreciate it.
Old 01-02-2013, 01:29 PM   #6
1slosix's Avatar
what do you mean specifications? the bulb size or what?
Old 01-02-2013, 01:44 PM   #7
Cali_JC's Avatar
Watts, I believe the bulb size is h13 and about the other criteria ? It asks
Old 01-02-2013, 01:54 PM   #8
1slosix's Avatar
35w if you want just double the lumens of standard halogen...55w if you want a bit over 3 times the lumens...it's the easiest way to think of it. also remember with 55w the color will wash out a bit so a color temp won't be the same in both 35w and 55w
Old 01-02-2013, 02:08 PM   #9
Terminator's Avatar
I had HiDs in my stock housing the beam was scattered an was to bright so had to get projector headlights to avoid a ticket
Terminator is offline   Reply With Quote
Old 01-02-2013, 02:19 PM   #10
Cali_JC's Avatar
Which did you have? eBay or ddm tuning ?
Old 01-02-2013, 02:24 PM   #11
Cali_JC's Avatar
So when checking out for a stock housing I'm thinking of doing 6000k H13 with mounting bracket
And also not buying the HID harness or error eliminator or adaptor cables. Does that sound correct ?
Old 01-02-2013, 02:44 PM   #12
Terminator's Avatar
i personally Always go with eBay because its where I first purchased an no problems
Old 01-02-2013, 03:39 PM   #13
1slosix's Avatar
yeah that's a good setup....here's my cutoff in my '04
Old 01-02-2013, 03:52 PM   #14
Cali_JC's Avatar
Is that 6000k ?
Old 01-02-2013, 05:13 PM   #15
1slosix's Avatar
yeah 35w 6k..granted it's a tad bit bluer in person, but my phone likes to adjust it to more white lol
Old 01-02-2013, 06:32 PM   #16
Cali_JC's Avatar
I was going for 8000k but because I was going to tint front windshield I didn't want to go too blue and compromise my visibility even more.
Old 01-02-2013, 06:56 PM   #17
1slosix's Avatar
then don't go 8k...that's more blue then what i have..and the bluer the light the less actual visible light you have
Old 01-02-2013, 07:37 PM   #18
Cali_JC's Avatar
I won't but thank you so much I really appreciate your help. I'm going to order mine soon as possible. So when ordering from ddm ill just need the mounting brackets correct ?
Old 01-02-2013, 09:40 PM   #19
Black on Boss's Avatar
55 watt 8000k is about the same color as 35 watt 6000k just so you know. I'm gonna order some 55 watt 8000k for my '11
Old 01-02-2013, 10:31 PM   #20
Cali_JC's Avatar
But as I said I'm going to tint my front windshield I want visibility as much as possible ha
Old 01-02-2013, 10:43 PM   #21
1slosix's Avatar
if that's the case then consider ordering a 55w 5k kit if you got the extra $20 to upgrade from the 35w kit...i use to run them in my old v6 and it was night and day difference even compared to what i have now
Old 01-03-2013, 07:28 AM   #22
Me too I'm probably only gonna do 50% instead of 32%. What are you goin to tint yours too ?
Old 01-03-2013, 07:37 AM   #23
Cali_JC's Avatar
I was going to do 35 % not too dark nor too light either
Old 01-03-2013, 07:42 AM   #24
On the front that's pretty dark bro. It might not look like it but a night you will have some issues. I was told this by my tint guy. He said if I plan on driving at night at all to go with 50%. There isn't that much difference in to the look but there is a visibility difference.
Old 01-03-2013, 08:03 AM   #25
Cali_JC's Avatar
Oh okay thanks for the heads up ! And 50 percent ain't that bad ?
Old 01-03-2013, 09:31 AM   #26
I'll say this. My tint guy had two identical trucks side by side. 5% all around . One 35% front one 50% front. They looked almost identical outside but inside the 32% was noticeably darker. I might get 32% anyways lol. I don't drive at night much. but he also said if I go 32% I will get hassled by the cops more often.
Old 01-04-2013, 12:03 AM   #27
Cali_JC's Avatar
Yeah more reason to grab attention from the 5-0. I might just do 5000k 55w hid kit and limo all around with 50 % tint windshield
Old 01-04-2013, 04:42 AM   #28
Comment not needed
Old 01-04-2013, 06:40 AM   #29
1slosix's Avatar
just be safe OP..front tint looks great but can be hard to run if you're a night driver.
Old 01-04-2013, 09:56 AM   #30
Cali_JC's Avatar
I agree with you, I'm just going to play it safe and do the 50% with the 55w 5000k hid
Old 01-05-2013, 08:28 PM   #31
Blogger
99ford's Avatar
Yeah 50 is the most I'd go they got 90% now it blocks all heat and reduces glare I almost did it on mine.
And you'll like the HIds the difference is night and day!
Old 01-06-2013, 11:59 AM   #32
Cali_JC's Avatar
Thanks again for your advice ! Ill post pictures once done !
Old 01-06-2013, 02:05 PM   #33
Blogger
99ford's Avatar
Np I can't wait to see it!
Old 01-06-2013, 08:08 PM   #34
NicholasP's Avatar
I wouldn't suggest xentec I've dealt with them before not a good product maybe it was just my set I'd suggest sonicelectronix for the best hids
NicholasP is offline   Reply With Quote
Old 01-06-2013, 09:26 PM   #35
Blogger
99ford's Avatar
^ good to know, and if anyone knows he would. He put them in mine
10:16 AM
