My 09 V6 mustang is messed up, and im desperate for answers. - Mustang Evolution
Old 01-02-2013, 01:15 PM   #1
I have a 2009 4.0 V6 five speed manual mustang, and one day my clutch gave out. im no expert in the mechanic department, but i love my car an i know a lot about it. well i took it in to get a new clutch, it cost me over 900 dollars total. as it came time to pick my car up i hopped in and turned in on, and it sounded like it gralled at me. its sluggish when i take off, when i switch gears it take and extra second or too for the gears to go into place, and if I'm in low rpm the cars does the same gralling noise. when i got to high speeds and let go of the gas the car jerks really bad. thats whats wrong on the outside. inside the AC stopped working, the engine light is on fallowed by a wrench light, and my cruise control will not turn on. my car is brand new only had it sense the summer with 46k miles on it so before i took it in everything worked perfect on my car and after the clutch repair all of this happened, can someone please tell me what this guy did to my car??? knowing is half the battle and i don't have a clue.
brandonbates is offline   Reply With Quote
Old 01-02-2013, 01:17 PM   #2
1slosix's Avatar
go straight back to the shop..tell them to double check all their work...really pricey for a clutch install so they better help you
carving corners like a boss
Old 01-02-2013, 01:24 PM   #3
okay, well i live a few hundred miles away from the shop, it all happened while visiting family, is it okay to keep driving it that much?
Old 01-02-2013, 01:27 PM   #4
1slosix's Avatar
depends on what they messed up on really..call the shop and talk to the head honcho...tell them your distance delima and see if they will allow you to visit a closer shop for an opinion. then go from there...if not your only choice may be to go back to the first shop. you may want to trailer it there to not damage your trans beyond repair. again that depends on what they did wrong.
Old 01-02-2013, 01:34 PM   #5
1slosix's Avatar
good luck
Old 01-02-2013, 01:37 PM   #6
Venomouz831's Avatar
Yea get a hold of that shop because that's a bit of money for that clutch. They might of not installed something right and have you checked what the codes are?
)02 Gt, Founder of WE2G
Old 01-02-2013, 01:38 PM   #7
it was a local shop, so im just gonna tow it over there see what they say, i have a feeling they may try to charge me again.
Old 01-02-2013, 01:41 PM   #8
1slosix's Avatar
if they do i'd be threatning a call to the BBB...it still works to put most places nuts in a vice if they are a larger shop or business...if it's a mom and pop place may not work lol...btw do you have paperwork stating workmanship?
Old 01-02-2013, 01:43 PM   #9
they said they had a little problem with the codes but fixed that, im not sure on what all that is so they may just used that to their advantage and told me everything was fine we i first picked it up.
Old 01-02-2013, 01:43 PM   #10
1slosix's Avatar
always find out the codes before a shop clears them and talks about fixing things.
Old 01-02-2013, 01:47 PM   #11
yes i have all the papers that prove they did the work, kept every receipt.
Old 01-02-2013, 01:48 PM   #12
Good now get in contact with them and tell them what you are having problems with.
Old 01-02-2013, 01:55 PM   #13
okay thanks so much.
---------- Post added at 02:55 PM ---------- Previous post was at 02:53 PM ----------
how would i be able to find out the codes?
Old 01-02-2013, 02:02 PM   #14
So are the codes still there? If not ask them what they were
v6 mustang
09:13 AM
