How do you remove the factory limits off the engine of a 2008 v6 mustang? - Mustang Evolution
Old 03-18-2010, 07:15 PM   #1
I think the company SCT make a module that can take this off. I know here in Australia a company called "CAPA" sells flash boxes that use software that can disable it. CAPA boxes are supplied Direct from the USA by SCT. You have to have your car professionally tuned though.
The box can change 1000's of parameters from air / fuel ratio to gear shift patterns. It was the XR6T owners hail from heaven.
Hope this helps
stanwyk55 is offline   Reply With Quote
Old 03-18-2010, 07:44 PM   #2
if you are talking about the top speed limiter u have to buy a chip costing around 300 dollars
no specific chip just a performance chip..but itll get u power too
redvers is offline   Reply With Quote
Old 03-18-2010, 07:55 PM   #3
Hard programmed into PCM - you will need a reprogram or other self programming device to modify the strategy in the PCM.
sidney16 is offline   Reply With Quote
v6 mustang
10:52 PM
