I am planning on modding my 2007 v6 mustang and need help!? - Mustang Evolution
Old 03-19-2010, 11:45 PM   #1
ps: how about 4.10 gears for auto? thanks
Zimra is offline   Reply With Quote
Old 03-20-2010, 12:00 AM   #2
yeap for an auto 4.10 gears are the best, and you just start on your basics. cold air intake, cat back exhaust, gears, under drive pulley, and finally a handheld tuner. the cai-5hp, exhaust-10hp, gears-no hp under drive pulley-5hp, and tuner-10hp so you should jump from 210hp to about 230hp and as far as your 0-60 time it should go down to about 6-6.5 sec
ok now what a tuner does is messes with your ecu, your ecu sometimes takes a really long way around to tell the car to move bc there are other things that it does first so the tuner kinda skips all that and make the ecu Response faster and you just plug the tuner into something that is under the steering wheel.
wolfe is offline   Reply With Quote
Old 03-20-2010, 12:28 AM   #3
I had the same question on the tuner. I'm thinking it's a chip for the computer.
A chip, and exhaust will help.
Depending on what gear you have in it now. Rather then just changing just ring and pinyon. You might have to change the carrier also. On most 3.73 is the turning point.
3.73 and lower (4.10 , 4.11 and so on goes on one carrier and higher goes in anouther. If you never messed with setting up a rear end. let someone else do it.
Theses would be quick fixes.
To get even more doing some top end engine work would give you even more.
And remember
IT"S NOT HOW FAST YOU WANT TO GO
IT"S HOW FAST YOU CAN AFORD TO GO
maxfield is offline   Reply With Quote
Old 03-20-2010, 12:49 AM   #4
Mustangs the Wal mart of cars
everywhere you look you will see one
gillecriosd is offline   Reply With Quote
Old 03-20-2010, 01:18 AM   #5
old school v8 it. look on you tube.
coty is offline   Reply With Quote
v6 mustang
05:47 AM
