Launching the 4.0?! - Mustang Evolution
Old 01-07-2013, 08:32 PM   #1
08Mustang's Avatar
Launching the 4.0?!
Ok so I was at the track this weekend and went against this 2012 v6 camaro a couple times and could not beat him but I've seen 4.0s beat em before! But I was spinning til like 55mph! How can I launch my car better? It's an auto
08Mustang is offline   Reply With Quote
Old 01-07-2013, 08:50 PM   #2
Rcary's Avatar
these other 4.0 modded at all (gears, tunes, can)? and launching on an auto aint hard just gotta get the timing mostly and floor it. idk if traction on/off makes a difference some ppl say it does and ive also heard not so much
Rcary is offline   Reply With Quote
Old 01-07-2013, 08:51 PM   #3
1998's Avatar
Did you have oil on the tires because there is no way a 4.0 is spinning all the way to 55. Maybe if it was forced induction. The only time my car squeals the tires is a small chirp from 2nd to 3rd. Also there is no way you'll beat a new camaro unless the other guy is a useless driver.
1998 is offline   Reply With Quote
Old 01-07-2013, 08:53 PM   #4
Rcary's Avatar
Yep the new camaros are faster than the 4.0s unless he messed up shifting against the other 4.0 that u speak of so in that case it would be him being a useless driver
Old 01-07-2013, 08:55 PM   #5
Were those other 4.0s modded at all? Cause i think 210hp/240tq against 323hp/279tq wouldn't favor the 4.0 at all. How are your tires? Ive never really heard of a 4.0 spinning tires that much, especially as an auto its harder to spin tires.... Theres a ton of different variables coming into play right now.
---------- Post added at 07:55 PM ---------- Previous post was at 07:54 PM ----------
I know JimC's old 4.0 could probably beat it, but his was XCharged.
Old 01-07-2013, 08:56 PM   #6
1998's Avatar
I just thought of something. Was it extremely cold when you went? Because the cold ruins your traction
Old 01-07-2013, 09:22 PM   #7
davidcseifert's Avatar
Region: Arkansas
i'm assuming you're using stockish tires, lower your pressure some for better traction off the launch, street tires generally 24-26psi is good range
also most street tires produce oils when they get too hot so you don't burn them you just spin them over a little to clean them off, others like the nitto 555's like a little heat to them, mine loved a 5 second burn and 24psi, cut a 1.96 60'
blower/new cam soon
Old 01-07-2013, 09:26 PM   #8
ForsakenProto's Avatar
Ive gone against and beaten a buddies 2011 v6 Camaro in my 2000 v6. All just luck of the draw and power to weight. All ive got are very basic bolt ons and a bama tune at that time.
ForsakenProto is offline   Reply With Quote
Old 01-07-2013, 09:35 PM   #9
1slosix's Avatar
can you post the slips OP? this might help us help you figure out what happened with your spinning
carving corners like a boss
Old 01-08-2013, 08:28 AM   #10
Wmcgrattan's Avatar
Upgrade your suspension get a LSD from am control arms 4:10 gears etc it will put more power to ur tires an give u alot faster launch all that's less then 1000$ on am an I'm sure you could find some of it cheaper else where
Wmcgrattan is offline   Reply With Quote
Old 01-08-2013, 02:04 PM   #11
08Mustang's Avatar
Yeah I'm not stock so maybe cause I've got more power. Got Pypes mid muffler catback, Pypes shorty headers, accel coil pack, and sr throttle body spacer. And I've got Pirelli zr18 zero nero tires and yeah it was probably 45 degrees out
Old 01-08-2013, 02:33 PM   #12
Region: Arkansas
Those don't yield near enough power to do that.. I'm gonna assume you didn't clean tires and just laid into it without feathering to keep it hooked
blower/new cam soon
Old 01-08-2013, 03:02 PM   #13
08Mustang's Avatar
Well I did not fully hook up until 55mph and then I could feel it starting to really pull
Old 01-08-2013, 03:05 PM   #14
Region: Arkansas
Drop tire pressure some next time, and a posi would do wonders
blower/new cam soon
Old 01-08-2013, 03:20 PM   #15
08Mustang's Avatar
Yeah no kidding, whoever decided to leave an open differential on our cars was an idiot!
08:55 PM
