spark plug wire. - Mustang Evolution
Old 01-18-2013, 07:10 AM   #1
Audicrashdummy's Avatar
spark plug wire.
Ive changes my spark plugs but I never did my wires. Is there anything special I need to do?
Audicrashdummy is offline   Reply With Quote
Old 01-18-2013, 05:57 PM   #2
Wmcgrattan's Avatar
Nope just plug an play but I'd suggest the gms coil pack from am.com
Wmcgrattan is offline   Reply With Quote
Old 01-19-2013, 01:11 PM   #3
I just used motorcraft again
Old 01-26-2013, 05:31 AM   #4
pamson's Avatar
as a rule of thumb, in my opionion when it's time to change plugs it's time to change wires. Why spend money on new plugs if your wires are'nt delivering the juice? As plug wires age they break down causing more amps needed to push the same amount of voltage to your plugs, less fuel milage and loss of power. Basicly the same reason plug gap is so important as gap increases from use the more amps are needed to push the needed voltage across the electrodes this causes lower spark temp which means less fuel burn before exhaust valves open and more unburned fuel goes right out your tail pipes.
pamson is offline   Reply With Quote
Old 01-27-2013, 09:33 AM   #5
05MUSTANG4.0L's Avatar
anybody know the what the spark plug gap should be?
05MUSTANG4.0L is offline   Reply With Quote
Old 01-27-2013, 11:24 AM   #6
Cobrarunnin9s's Avatar
The VECI sticker will tell you plug gap recommendations
Cobrarunnin9s is offline   Reply With Quote
Old 01-27-2013, 08:41 PM   #7
Should be either 51. Or 52.
Old 01-30-2013, 12:21 PM   #8
thanks for the help.....
09:43 PM
