Water in Rear Quarter Panel - Mustang Evolution
Old 01-19-2013, 10:18 AM   #1
Blogger
99ford's Avatar
My Right Rear Quarter Panel has decided to take on a reserve supply of water. I've checked all the drains and as far as I can tell they are clean and clear of debris.
So once it drains out how do I prevent it from coming back in?
Old 01-19-2013, 12:16 PM   #2
sprdave's Avatar
Well you need to figure out first where the water is getting in.If it was me, I would
try took check all the window rubber seals first.If I could not find the cause,I
might considered drilling more holes for the water to drain out.Maybe do a web search
as possibly someone has had this same problem.Good luck!!
sprdave is offline   Reply With Quote
Old 01-19-2013, 04:16 PM   #3
Blogger
99ford's Avatar
I guess it could be coming in through the rear window, but it is a convertible.
I was alsowondering if anyone else has had this issue and what they've done to fix it.
Old 01-23-2013, 08:19 PM   #4
Blogger
99ford's Avatar
An update: I lowered the top and found 1/2 inch of water in there took my Rigid Wet/Dry and sucked out along with acorns, and pine needles galore. When I finally got the holes free, I tested it out by running water along the side all drains are working and panel isnt filling up with water.
01:58 PM
