LCA need help! :) - Mustang Evolution
Old 01-31-2013, 04:56 PM   #1
JetWolf's Avatar
Send a message via Skype™ to JetWolf
LCA need help! :)
LCAs are shot, looked under Jet and saw bushings are the problem, should i just order a whole new set of LCAs or just bushings? Which is harder to install? and could any of you walk me through it? haven't had much experience with suspension yet, and i do have access to lift and whole shop of tools.
Thanks guys!
2006 JetWolf Gilbert, AZ. Come race me, I dare you. ASU!
JetWolf is offline   Reply With Quote
Old 01-31-2013, 06:54 PM   #2
Mkolabin's Avatar
Never done it. Can't say.
Just wanted to pop in here and offer you my moral support. Sorry to hear your 'Stang is coming up lame. The good news is, unlike a real mustang, yours can be fixed and won't need to be shot.
Mkolabin is offline   Reply With Quote
Old 01-31-2013, 07:09 PM   #3
monkey13's Avatar
Thanks guys!
Hey jet.. Well its totally up to you.and.budget really. You can do both. If your looking to improving then new aftermarket would be the way to go. If just looking to replace and fix then you can go with just bushings
monkey13 is offline   Reply With Quote
Old 01-31-2013, 09:11 PM   #4
JetWolf's Avatar
Thanks much appreciated <3 ahahahahahaha that's awesome, and thank God, 10k is not worth shooting!
Bushings were cheaper, in college and can't splurge, that's why I do all the work. Thing is do you need any specialty tools to remove/ install the bushings? Asked mech (normally on my own but really don't know this area so well as I should) said you'll need a special machine to push everything in and I was all what.
Little confused on install.
Old 02-01-2013, 12:06 AM   #5
monkey13's Avatar
Not necessarily .. What your is your??? There's always ways of getting around special tools specialy if you have a lift
Old 02-01-2013, 09:24 AM   #6
Cobrarunnin9s's Avatar
You only need to press the bushings into the rearend housing itself for the upper control arms. The bushings for the arms themselves just slide in. And changing the whole arm is really easy. Put jack stands under the rear and use a jack to lower the control arm down with the spring. Swap em and bolt them back up.
Cobrarunnin9s is offline   Reply With Quote
12:23 PM
