high cold idle - Mustang Evolution
Old 02-12-2013, 10:03 AM   #1
Atrav83's Avatar
high cold idle
When emissions rolled around I had to take my CAI off, and after putting it back on the stang has been acting weird. On the first start of the day it idles really high at about 1500 instead of 900 rpms, should I take it in to get checked out?
Atrav83 is offline   Reply With Quote
Old 02-12-2013, 10:26 AM   #2
Vicello93's Avatar
Mine does the same but it was like that with the stock intake.. Maybe the temperature outside it too cold?
Vicello93 is offline   Reply With Quote
Old 02-12-2013, 10:28 AM   #3
Atrav83's Avatar
I don't think so, I live in Cali lol
Old 02-12-2013, 10:54 AM   #4
Vicello93's Avatar
Lol I live in nj It's cold here
Old 02-12-2013, 11:01 AM   #5
Atrav83's Avatar
The weirdest thing is that today after not starting it all weekend it idled even higher, 1700-1800 rpms before I put it in gear and it died down to 800-900, which is what freaked me out and why I'm asking now lol
Old 02-12-2013, 11:14 AM   #6
Tyoung68's Avatar
Are all you sensors plugged in?
Old 02-12-2013, 11:20 AM   #7
Atrav83's Avatar
Ya I believe so, I'll check after class today.
And I forgot to mention the stupidest thing I've ever done lol I went to take off and clean the filter after I put the CAI back on after emissions and I put a towel over the arm to cover it and early the next morning for school my dumb *** starts it with the towel over it thinking I put the filter back on. Would that have clogged anything up that I need to clean??
Old 02-12-2013, 11:21 AM   #8
Tyoung68's Avatar
Did you suck the towel in?
Old 02-12-2013, 11:33 AM   #9
Atrav83's Avatar
No it didnt , the towel didn't even move thank god, but could it have gotten debris or clogged something up?
Old 02-12-2013, 06:37 PM   #10
Zhim's Avatar
did you try a reset? I'm assuming you're running without a tune? Maybe your engine ran rich because it wasn't drawing enough air with the towel over the intake and freaked out for a bit.
Zhim is offline   Reply With Quote
Old 02-12-2013, 07:30 PM   #11
Atrav83's Avatar
No I have a tune, and when I did that it was still stock, it was before I put the tune back on
Old 02-12-2013, 08:00 PM   #12
Tyoung68's Avatar
Was it fine with your old air intake?
Old 02-12-2013, 08:08 PM   #13
Atrav83's Avatar
It was perfectly fine before I had a moron moment and started it with the towel covering the arm and no filter, so I was thinking maybe some debris or something got dirty in there that's messing up the idle at start
Old 02-12-2013, 08:11 PM   #14
Tyoung68's Avatar
Yeah just check all you sensors and make sure theyre all clean
Old 02-12-2013, 08:47 PM   #15
Atrav83's Avatar
Which ones specificly should I check? The MAF and what else is there? Sorry I'm not too savy on much of how the engine works yet, learning in progress lol
Old 02-15-2013, 10:58 AM   #16
Audicrashdummy's Avatar
I wanna say its temperature outside. I'm down in tx and mine has been doing that too. It'll jump to about 1500 and sit there for a minute of two until it gets warm. I never noticed it until it got cold. I have an all stock engine just new plugs and wires but that wouldn't change it.
Audicrashdummy is offline   Reply With Quote
Old 02-21-2013, 01:21 AM   #17
Atrav83's Avatar
Ok cool thanks for the help guys
Old 02-21-2013, 01:25 AM   #18
austinknoll's Avatar
On cold startups the engine will need to warm up so the idle will be higher. Doesn't it go away in a few seconds?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 02-21-2013, 06:01 AM   #19
No few minutes. Now I didn't notice this until a few weeks ago and my thermostat housing has been cracked for a few weeks. Would that cause other problem?
08:02 PM
