Harmonic Balancer Replacement help - Mustang Evolution
Old 02-23-2013, 08:48 AM   #1
Nick2014's Avatar
I just recently found out that a squeaking noise in my car was the harmonic balancer pulley had slipped bad. Now it's so far back that I can't even keep a belt on there because it wants to slip off everytime. I contacted some shops and they wanted a pretty nice chunk of change to replace it so I was wondering if it would be easier to just do it myself?
Nick2014 is offline   Reply With Quote
Old 02-27-2013, 06:49 PM   #2
dolfin13's Avatar
Don't keep driving it. If something breaks off its gonna get inside the motor and then your screwed. Mine went on my car. The mechanic told me its pretty common. They only charged me 150 bucks. Unless your mechanically inclined you shouldn't do it. Take a look at a video first on you tube on how to do it
dolfin13 is offline   Reply With Quote
Old 02-27-2013, 08:06 PM   #3
jdavis96gt's Avatar
Region: West Virgina
Go rent or buy a pulley installer. Pretty easy job, hour or two.
Old 03-12-2013, 10:49 PM   #4
Mr. SoloDolo's Avatar
Same thing happened to me and it was a complete and total disaster when i tried myself not to say it isnt easy but im mechanically inclined had all the right tools and still wound up brining it to the shop it had never been removed before and kind of seized up inside of the lower block
Mr. SoloDolo is offline   Reply With Quote
Old 03-13-2013, 04:05 PM   #5
Nick2014's Avatar
Yeah I just brought it to the shop and they took car of it after they drained my wallet
Old 11-20-2015, 04:12 PM   #6
I noticed a wobbly harmonic balancer. There is a little bit of rubber sticking out of the edge also. In order to replace it looks like you need alot of special tools, maybe a special long puller. Can anyone confirm exactly what is needed? or has anyone bought the new pulley and had a mechanic install it?
kclight01 is offline   Reply With Quote
Old 11-20-2015, 10:23 PM   #7
Only "spercial" tool needed is pulley/installer and a few hand tools about 1 to 1 ans 1/2 hr job
ALLYDRIVER1 is offline   Reply With Quote
Old 11-21-2015, 01:36 AM   #8
Is this true? From what I have read I need the following:
OTC Crankshaft Vibration Damper Remover (303-101) T74P-6316-A
OTC Crankshaft Vibration Damper Installer Ford (303-102) T74P-6316-B
OTC Crankshaft Vibration Damper Remover (303-773)
303-D055 Harmonic Balancer Strap Wrench D85L-6000-A
Crankshaft Pulley Harmonic Balancer Bolt F5RZ-6A340-B
and of course the pulley itself...
Are you saying this can be done with just the new pulley and the installer (part 303-102)? I have read that most standard pullers don't work because they don't have a long enough bolt.
Old 11-22-2015, 08:36 PM   #9
Go rent a puller/installer kit from advance
02:05 AM
