Clutch or tranny? - Mustang Evolution
Old 03-02-2013, 09:49 PM   #1
gc19662007's Avatar
Clutch or tranny?
I've noticed a problem with my 07 V6 with 5 speed, not sure if its tranny or clutch, never had a clutch going out before. 1st through 3rd gear seems fine during normal driving but in 4th when I punch it the RPMs go up but it feels like there's no power for a couple of seconds and then it's starts kicking in but not as much as it used to. 5th gear running 60mph and punch it does the same thing. My driving habits are shifting around 2500 rpms and mostly freeway with occasional downshift to go around trucks.
I have 108k on the car now with all original drivetrain parts. only upgrades are a cold air intake (no tune & no codes ever thrown) and dual exhaust.
Any idea as to which one is most likely?
gc19662007 is offline   Reply With Quote
Old 03-03-2013, 02:51 AM   #2
MikesChargedGT's Avatar
Synchros?
"Too much horsepower is not enough"
MikesChargedGT is offline   Reply With Quote
Old 03-03-2013, 09:30 AM   #3
Region: South Dakota
So the engine revs up, but you don't get power immediately with the engine revving? If so that sounds like the clutch is slipping, and it would be time to replace it.
Combatman is offline   Reply With Quote
Old 03-03-2013, 10:25 AM   #4
Sorry about double posting, but I remember hearing somewhere that a good way to test your clutch is to start driving up a rather steep hill in the gear you normally would, then about half way up put it in a higher gear (than you would normally) and give it some gas. If the engine bogs then the clutch is probably alright. If it starts revving up but doesn't speed up much then you probably need a new clutch.
Old 03-03-2013, 05:20 PM   #5
gc19662007's Avatar
Thanks for the input, is clutch replacement easy or about what would it cost to have it done? I actually have more money than time, feels weird saying that.
Old 03-03-2013, 06:45 PM   #6
I haven't really done it myself, so I couldn't speak on the level of mechanical expertise required, but from what I understand its rather difficult. You have to pull the whole transmission if that's any indication to its difficulty.
Also from what I hear you want to make sure you replace all the bearings while you ( or your mechanic) are in there just to prevent having to pull out the transmission sooner than you would normally have to.
Also don't quote me on this; I don't really know from experience. This is just what I've read on the net.
Old 03-03-2013, 06:57 PM   #7
gc19662007's Avatar
Thank you. I'm gonna call my guy in the morning and see what he charges. I've pulled tranny's before, but like I said, no time to jack with it now. I will prolly just rent a car but will make sure he gets the while thing tip top while its out. I'd guess a full rebuild prolly wouldn't hurt while its out from under the car. I just hate being without my car for any amount of time.
Old 03-03-2013, 07:09 PM   #8
Well what ever you decide to do I wouldn't mind hearing the price; if that's not to personal. My transmission is a tad notchy and I'm curious what it might cost me to get it rebuilt
Old 03-04-2013, 06:32 AM   #9
If its a clutch don't bother with a tranny rebuild, its unesesary (I know that's spelled wrong)
Old 03-06-2013, 06:43 PM   #10
gc19662007's Avatar
Ouch, 600-800 bucks to replace the clutch. But its better than my butt underneath the thing pulling the tranny myself. The 6-8 doesn't include the tow charge or rental, I'm driving it until it won't go anymore.
---------- Post added at 08:43 PM ---------- Previous post was at 08:42 PM ----------
Still gotta break that to the wife and she's in a good mood tonight. Might just have to pick a fight tomorrow...
Old 03-06-2013, 06:49 PM   #11
gc19662007's Avatar
Yea I did the hill this morning, it revved up and dropped out again as its been doing on the freeway. Noticing it more in 2nd - 5th now. Even in cruise control, the hill kicks it out.
Old 03-12-2013, 01:02 PM   #12
gc19662007's Avatar
I took my car to 2 tranny shops and a garage I've used before. Unless they are in with each other in some way, they all told me that there were a couple of different clutches on the 07 and I've got the expensive one. Along with the flywheel, the new price is 1099.20.
Old 03-12-2013, 01:28 PM   #13
Are you replacing the flywheel or resurfacing it?
Old 03-12-2013, 01:52 PM   #14
gc19662007's Avatar
Was told it started to get heat/stress cracks so it has to be replaced.
Old 03-12-2013, 02:17 PM   #15
That would explain the price, the flywheel is about as expensive as the clutch from what I've seen, then tack on labor and that will probably get you in that price range.
Old 03-12-2013, 08:23 PM   #16
gc19662007's Avatar
The shop I took it to quoted 800 at first. Said he felt bad about the adjustment and kept it as far down as he could. I couldn't find the flywheel on auto zone or anything. If it runs about the same as the clutch then that's just under a grand for parts and he's doing it for a minimum. Figure 900ish in parts and couple hundred in labor. Still worth it to me, I got no lift now but my next garage will.
Old 03-12-2013, 08:36 PM   #17
Yeah I mean don't quote me on the price, but when I was researching for my '05 flywheels were just under or the same as the price of the clutch
Old 03-12-2013, 08:42 PM   #18
gc19662007's Avatar
Oh no I got you man. I couldn't find the flywheel for mine. Just saying that if those were close to the same as a clutch kit, then 1100 ain't too bad a price to have done considering parts are close to 1000. I'd have to guess at shop rates at least about 50 bucks an hour so 4 to 5 hours quoted by the three I priced it at, still came out ahead and would normally have to pay about 1200-1300.
Old 03-12-2013, 09:10 PM   #19
04:22 PM
