synthetic oil. - Mustang Evolution
Old 03-15-2013, 12:44 PM   #1
synthetic oil.
It won't affect the warranty if I change to synthetic oil right?
Andy714 is offline   Reply With Quote
Old 03-15-2013, 03:19 PM   #2
Wmcgrattan's Avatar
No
Wmcgrattan is offline   Reply With Quote
Old 03-15-2013, 04:21 PM   #3
Billymich's Avatar
You can also switch back to regular at any time, but a lot of ppl will tell you either not too, or to switch only to partial synthetic blends.
Old 03-15-2013, 04:43 PM   #4
Site Sponsor
Sponsor
AMWill's Avatar
Nope, as long as you're using the recommended oil specifications (ex. 5w30). Also, the only time switching back and forth between synthetic and conventional shows to be an issue, is on high mileage cars.
Most synthetic blends have high amounts of detergents in them, which will break apart any "gunk" that's built up in the engines creases. So, a high mileage car is more likely to have "gunk" built up between gaskets, which is actually preventing a potential oil leak, assuming the gasket is on it's last end. When the synthetic oil is used, the detergent will break apart the "gunk" and open up a leak, if the gasket can't hold!
Just a little tech info for ya!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 03-15-2013, 08:45 PM   #5
Shane
So synthetic is more likely to cause leaks than conventional?
Old 03-15-2013, 09:23 PM   #6
Wmcgrattan's Avatar
No it only causes leaks if you use synthetic an switch back in forth with regular oil cause it will **** your gaskets up but id recommend picking synthetic an sticking with it
Old 03-16-2013, 08:40 PM   #7
08Mustang's Avatar
Yeah I've done synthetic since the first change on my 08 when I got it and that was about 15k miles ago
08Mustang is offline   Reply With Quote
Old 03-19-2013, 02:21 PM   #8
Site Sponsor
Sponsor
AMWill's Avatar
No, I'm simply stating that switching back and forth could cause a weak spot in your gaskets. If you stick with synthetic full time and are always prompt on your oil changes, there will be no extra slug to begin with.
Hope this clears things up!
Shane
Old 04-22-2013, 01:06 AM   #9
Bladezx's Avatar
So I've been using regular oil on my 12 the whole time and it's at 41k so would it be good or bad to change to synthetic? I was thinking about switching to amsoil.
Bladezx is offline   Reply With Quote
Old 04-22-2013, 04:44 AM   #10
08Mustang's Avatar
It's not gona hurt anything to switch, only beneficial
Old 04-24-2013, 07:30 AM   #11
No
Bakiebruno5 is offline   Reply With Quote
06:09 AM
