Steering Wheel Shakes - Mustang Evolution
Old 03-17-2013, 10:15 AM   #1
mOnteezY's Avatar
Just got me new dubs installed and upon driving I noticed my steering wheel shaking. Not crazy shaking but enough to notice. Does that happen on newly installed 20" rims? Or is it a balance problem? I was there when the guy balanced the wheels and it balanced out correctly. Any suggestions or input?
mOnteezY is offline   Reply With Quote
Old 03-17-2013, 10:36 AM   #2
Jgill1992's Avatar
Alignment or tire pressure. Get it checked it should not shake if everything is done correctly.
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 03-17-2013, 10:38 AM   #3
blackhawk 1's Avatar
all mustangs need the camber caster installed
blackhawk 1 is offline   Reply With Quote
Old 03-17-2013, 10:58 AM   #4
08Mustang's Avatar
You went from a massive profile of rubber to a very thin layer of rubber so it's just less cushioning that you're feeling
08Mustang is offline   Reply With Quote
Old 03-17-2013, 11:40 AM   #5
Krazy Horse's Avatar
Maybe the centering of the wheel to the hub off size, the center hole on the wheel larger than the hub on the car, needs centering disc inserts to stop the shake or go back to old wheels to confirm it is wheels
Krazy Horse is offline   Reply With Quote
Old 03-17-2013, 01:21 PM   #6
Boomdizzle's Avatar
I'd say the wheels aren't balanced properly or your steering is out if alignment. The alignment could be more pronounced with the bigger wheels especially of they are wider.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 03-17-2013, 01:49 PM   #7
Only use Roadforce Balance machines. Most shops have them by now.
Old 03-17-2013, 03:55 PM   #8
mOnteezY's Avatar
Thank you all for the replies, I was thinking of taking it in to America's Tire Co. to get it realigned. I'll keep y'all updated to how it went.
Old 03-18-2013, 07:15 PM   #9
Claypops's Avatar
Is it when you brake or all the time? I have 20s on mine as well and mine starts to shake when I brake. I just replaced the pads 300 miles ago and it still does it. I think it's my rotors
Claypops is offline   Reply With Quote
Old 03-18-2013, 08:37 PM   #10
Vicello93's Avatar
I have the same problem but I have stock rims and tires, and when I go about 55+mph my steering shakes... Alignment maybe?
Vicello93 is offline   Reply With Quote
Old 03-18-2013, 10:16 PM   #11
mOnteezY's Avatar
Oh no just when driving. But it's been going away. It's not too noticeable now. I'm still going to get it rebalanced to be safe.
---------- Post added at 09:16 PM ---------- Previous post was at 09:16 PM ----------
Yeah with stock it may be your alignment.
Old 03-19-2013, 07:26 AM   #12
Vicello93's Avatar
Got it! Thanks!
Old 03-21-2013, 10:03 PM   #13
I had that problem with my old 04... I got used to it after a while
ThatsCoolBro is offline   Reply With Quote
06:52 PM
