Starting Problem on V6 - Mustang Evolution
Old 03-22-2013, 07:24 PM   #1
MustangGirl1994's Avatar
Region: New Hampshire
My 2008 V6 Mustang will not start. I know it is the starter. My friend has the same problem and it will not start one day and then it works again. But I do not know if my car is going to do the same. My friend took her car to the garage to get check and the the guy told her that the battery, the starter, and the alternater are all ok. So I was just curious if there was a problem that is going on with the 2005 and 2008 Mustangs.
MustangGirl1994 is offline   Reply With Quote
Old 03-22-2013, 08:14 PM   #2
fastmustangs1's Avatar
could be a bad ground. Have u checked other thing like plugs n wires perhaps.
fastmustangs1 is offline   Reply With Quote
Old 03-22-2013, 08:20 PM   #3
Yes. We checked the grounds. We also check the relay switch but we are going to do that again in the morning so that we have light. But I have not checked the wires. Its hard to look with just a phone's flashlight. So we are waiting for morning to go over it more. Plus for my friend's mustang. When it gets a jump when dead it will start but the next week it dies again.
Old 03-22-2013, 09:57 PM   #4
Nfreeman40's Avatar
Does it make any sounds when you turn the key? Any clicks or flashing lights, theft light especially.
Nfreeman40 is offline   Reply With Quote
Old 03-23-2013, 11:04 AM   #5
Does a clicking noise that sounds as though it is coming from the engine. But all my dashboard lights come on, my radio works, my windows work, and my wipers work.
Old 03-23-2013, 11:38 AM   #6
I do know that it is not the battery because I have a new battery in it. Plus it isn't making the noise as though the battery is dead. Plus we have already tried to jump it but it does not work.
Old 03-23-2013, 01:31 PM   #7
Nfreeman40's Avatar
This may sound funny but try moving your steering wheel up and try to start it and if that doesn't work move it down and try that. My 99 v6 stang had a loose connection in the steering column and would only start when I tilted the wheel.
Old 03-24-2013, 06:27 PM   #8
It was the starter. It had a crack in it.
11:50 AM
