Water lever sensor - Mustang Evolution
Old 03-23-2013, 02:55 PM   #1
Super's Avatar
Water lever sensor
My wife's engine light came on last week had it read and it was the coolant lever. So I filled the tank back and reset the code. Now it keeps coming on after a day are two. I'm guessing a sensor is going bad. I need to know how hard it is to change a water lever sensor in a 07 v6 mustang.
Super is offline   Reply With Quote
Old 03-23-2013, 04:43 PM   #2
tonyd01gt's Avatar
hi, if the sensor is in the coolant reservoir. You can try clean the reservoir out. and move the float around. Most of the float level you cannot change. just replace the reservoir.
tonyd01gt is offline   Reply With Quote
Old 03-25-2013, 04:25 AM   #3
Super's Avatar
Thanks tony I'll check that out today.
Old 03-26-2013, 02:42 PM   #4
Next_up23's Avatar
How it turn out
Next_up23 is offline   Reply With Quote
Old 03-26-2013, 06:17 PM   #5
Super's Avatar
Still working on it. I drained the tank cleaned the float off and refilled the system. Waiting to see if it worked if not guess ill replace the reservoir.
Old 04-05-2013, 11:15 PM   #6
Super's Avatar
It turns out it was the sensor for the coolant temp. Replaced that and the thermostat cleared out code and hasn't came back on since.
05:20 PM
