How much HP - Mustang Evolution
Old 04-11-2013, 05:34 PM   #1
FRESH's Avatar
How much HP
Can a V6 eng hold before it start give u trouble
FRESH is offline   Reply With Quote
Old 04-11-2013, 05:44 PM   #2
Wmcgrattan's Avatar
The 4.0 can stand some power but if ur doing any type of fi or spray it would be good to get forged internals just incase
Wmcgrattan is offline   Reply With Quote
Old 04-11-2013, 06:02 PM   #3
JimC's Avatar
The 4.0 will take a lot. I put 203,000 miles on my 2006 - with nitrous followed by the Xcharger at 90,000 miles (not both though, it won't last with dual power adders).
No need to forge the engine - there are many many many of them out there with lots of miles and lots of boost with no issues.
The limit that my friend found was when he hit it with 18lbs of boost and about 500 rwhp. Another friend is running a turbo with 16 lbs of boost and 475 rwhp and has been for some time now. Again, stock engine with just the valve springs changed to avoid valve float.
JimC is offline   Reply With Quote
Old 04-11-2013, 10:18 PM   #4
Bschmidty's Avatar
I'm thinking of getting FI sooner or later.. How does the drivetrain/suspension hold up with a turbo?
Bschmidty is offline   Reply With Quote
Old 04-12-2013, 04:26 AM   #5
JimC's Avatar
You will need to replace the 7.5 open diff rear end with the 8.8 from a 2005-10 GT or a 2011+ Mustang. The 7.5 won't handle the power for long and you can't build it up stronger to take it.
With the increase in power you should replace the rear lower control arms with something stiffer, but it isn't a requirement. Just makes it easier to get the power to the ground without the soft LCA soaking up the power.
The manual transmission is a weak spot, the automatic can handle the power with no problem. Many of the manual guys have upgraded that transmission with an adapter plate for the 3650 made by a guy over at MustangCollective.com by the name of Nice Pony.
Old 04-12-2013, 06:24 PM   #6
FRESH's Avatar
I have a auto so that mean I can keep my transmission
Old 04-12-2013, 07:53 PM   #7
Bschmidty's Avatar
I'd upgrade to a 8.8 rear end. That's what I'm gonna do next year maybe
06:05 PM
