2007 v6 4.0 injector upgrade - Mustang Evolution
Old 05-05-2013, 04:51 PM   #1
Cool 2007 v6 4.0 injector upgrade
Where is the best place to find new injectors that are bigger than stock that would be good to use without a turbo kit but with many other mods for better air/fuel ratios?
JustJ03v6 is offline   Reply With Quote
Old 05-05-2013, 05:56 PM   #2
JimC's Avatar
Bigger injectors aren't going to give you a better AFR. That can be accomplished in the tune with the stock injectors.
JimC is offline   Reply With Quote
Old 05-05-2013, 06:20 PM   #3
Will that increase the power output as well then without installing bigger injectors? Then what is the point of bigger injectors?
Old 05-05-2013, 06:33 PM   #4
1lowGT's Avatar
Get more fuel
Old 05-05-2013, 06:36 PM   #5
Obviously, but if you don't supposedly need more fuel for more power like what was said above, then what's the need for bigger injectors if you can get the same results with a tune?
Old 05-05-2013, 06:49 PM   #6
1lowGT's Avatar
You don't need bigger injectors because you don't have enough power that requires more fuel. So a tune will get you more power with stock injectors.
Old 05-05-2013, 06:55 PM   #7
So you only need bigger injectors if you add a turbo or spercharger to the stang? What other mods would require bigger injectors?
Old 05-05-2013, 07:01 PM   #8
1lowGT's Avatar
Well if you're near stock hp then no need. But yes FI would require.
Old 05-05-2013, 07:01 PM   #9
JimC's Avatar
Adding a turbo or supercharger is the only mod where you need bigger injectors - because the stock injectors can't add enough fuel for the added air you are forcing into the system. On a naturally aspirated car you don't need them because the stock injectors can keep up.
Old 05-05-2013, 07:49 PM   #10
Someone had told me that they mounted a front mount intercooler with one side closed off for more air mass n swapped injectors n made more power. There was no turbo installed.
Old 05-05-2013, 07:52 PM   #11
1lowGT's Avatar
More air isn't gonna do anything through stock intake
Old 05-06-2013, 04:53 AM   #12
JimC's Avatar
I'm sorry, but that doesn't make any sense -
Old 05-06-2013, 08:47 AM   #13
1lowGT's Avatar
+1 lol don't listen to that person.
Old 05-06-2013, 11:41 AM   #14
So would it if you upgraded your throttle body to the 70mm?
Old 05-06-2013, 03:31 PM   #15
Bschmidty's Avatar
If you have a tune it will adjust accordingly. No need to upgrade injectors for anything other than forced induction
Bschmidty is offline   Reply With Quote
11:53 PM
