New rear - Mustang Evolution
Old 05-06-2013, 03:38 PM   #1
Mustangkid34's Avatar
New rear
What would I need if I wanted to change my rear to a 8.8 inch rear?
Mustangkid34 is offline   Reply With Quote
Old 05-06-2013, 04:18 PM   #2
aegischief's Avatar
An 8.8 rearend assembly from a mustang of the same year group is the easiest way.
aegischief is offline   Reply With Quote
Old 05-06-2013, 05:24 PM   #3
Bschmidty's Avatar
If you were to get one I believe you need a cobra flange
Bschmidty is offline   Reply With Quote
Old 05-06-2013, 05:38 PM   #4
08Mustang's Avatar
Yea cobra pinion flange to mate up to the v6 drive shaft
08Mustang is offline   Reply With Quote
Old 05-08-2013, 01:51 PM   #5
Try to find a wrecked GT and swap it out.
Old 05-08-2013, 09:30 PM   #6
JimC's Avatar
First it has to be from a Mustang, 2005+ model year. I see all the time where someone buys an 8.8 for a different model and then asks how to mount the 4 link rear end they bought (or the leaf spring type from an Explorer) on the 3 link system the S197 Mustang uses.
If the rear end comes from a 2005-10 model year then you need to swap the pinion flange with the cobra flange so the driveshaft will mate up. If the rear end comes from a 2011+ the pinion flange should already be correct to mount to the 2005-10 V6 driveshaft.
JimC is offline   Reply With Quote
10:17 PM
