Engine Temp when flooring - Mustang Evolution
Old 05-14-2013, 07:38 PM   #1
Kustumb's Avatar
Hey guys,
So I was just passing this guy on the highway and I floored the pedal. After I passed him I let go and a couple of seconds later my temperature gauge shot way up (close to red). After that it went to its normal mid position again a second later. Is this normal or should I get my car checked?
Kustumb is offline   Reply With Quote
Old 05-14-2013, 08:12 PM   #2
joedelpen's Avatar
Region: Nevada
Originally Posted by Kustumb View Post
Hey guys,
Not a certified Machanic. But when you do floor it your temp will go up. Not into red though unless you where over pushing your rpm and you blew something. But it is normal for your temp to go up just not clear into red. You running All stock? I blew hoses onetime like that in a different car once. But if everything's running normal. You most likely just over temped your engine and the thermostat just opened late. Get it normally tuned up just to make sure. And have your cooling system checked just to rule out a sticky thermostat... That's what I would do if I was concerned. Like I said I do my own work on mine so it's on a situation basis. Good luck
POLICE PROTECT AND SERVE THIER WALLETS
joedelpen is offline   Reply With Quote
Old 05-14-2013, 08:15 PM   #3
Kustumb's Avatar
Everything is stock. The gauge didn't go INTO red but was right at the border of getting there. The car sounded perfectly fine so I'm not sure if I blew anything. I'll check just to make sure.
Thanks!
Old 05-14-2013, 08:20 PM   #4
joedelpen's Avatar
Region: Nevada
I think your ok then. Temp goes up when you floor it. Mine does. It's just hi temp from all the piston fire then the thermostat opens and it goes right back down to norm. Your good. A check never hurts to keep our stangs right...
Old 05-14-2013, 08:20 PM   #5
Kustumb's Avatar
Thanks buddy!
Old 05-30-2013, 07:23 AM   #6
05MUSTANG4.0L's Avatar
Are any of the other gauges not working?
05MUSTANG4.0L is offline   Reply With Quote
Old 05-30-2013, 11:20 PM   #7
Kustumb's Avatar
To my knowledge, all my gauges are working fine. And I've done a few hard starts since then and haven't noticed the temp going up like that again. Maybe it was a fluke.
06:50 AM
