Troubles taking off in first gear - Mustang Evolution
Old 05-18-2013, 02:13 PM   #1
Region: South Dakota
So I've driven a few other manuals before, but this one has definitely been the hardest to take off with.
The issue is when I start putting gas on it as I let out on the clutch, if I don't put enough the rpms drop to like 500 then go back up anthem the clutch starts to catch. The only way to get around this that I have found is to rev the engine to like 1250-1500 before I start letting out on the clutch. Is this normal?
Combatman is offline   Reply With Quote
Old 05-18-2013, 02:37 PM   #2
That happens to me in my 01, but I don't know how the clutch is like in the 05, I don't have a hydraulic clutch (which I personally like). You probably just need to learn the clutch. Between my dads corvette and my mustang I actually like my clutch a lot better.
Maybe someone else has some other insight.
Old 05-18-2013, 02:44 PM   #3
Seabiscuit's Avatar
I don't believe I had that problem in my 05. I know if I didnt give it enough gas it would buck like crazy. How many miles are on it?
Seabiscuit is offline   Reply With Quote
Old 05-18-2013, 03:01 PM   #4
88000 miles, I was thinking maybe the hydraulic clutch fluid, but I don't know how to check that.
I've done the speed check on the clutch (low speed high gear) and the clutch was fine.
I don't think it's a matter of getting used to it, as I've been driving it as my daily for about 3 months now.
Old 05-18-2013, 04:09 PM   #5
Mine is the same way. Made me feel like a complete newb when I first got the car. Stalling at lights and such. Lol. I learned how to drive in a manual. Recently, I drove a '13 5 litre and the hydraulic clutch seemed alot smoother. I like the feel of ours though. Don't worry. With time, you will master it.
straybullitt is online now   Reply With Quote
Old 05-18-2013, 04:25 PM   #6
Alright, we'll is it bad to rev the engine up a little to take off? Am I putting significant wear on the clutch by taking off at 1250-1500?
Old 05-18-2013, 05:00 PM   #7
I have been waiting for the clutch to start engaging before giving it any gas. Go find a level parking lot and practice slowly letting out the clutch without touching the gas pedal. This will give you a feel for where the clutch is engaging the flywheel.
Old 05-18-2013, 05:13 PM   #8
Thats usually where i rev it up to, just let it out a little quicker the more gas you give it.
Old 05-19-2013, 01:01 PM   #9
usmc.Cavanaugh's Avatar
Does it let out high or low is the pedal hard to push because it could be the clutch could be the slave cylinder causing the problem
usmc.Cavanaugh is offline   Reply With Quote
Old 05-19-2013, 01:40 PM   #10
The clutch is pretty stiff, and it lets out really soon after pushing in, so really high?
How hard is it to replace the slave cylinder?
Old 05-22-2013, 05:47 PM   #11
If its really high that's good but if its really stiff like your pushing down pretty damn hard than its the slave cylinder it's a ***** and you have to drop the trans to get to it
Old 05-22-2013, 06:57 PM   #12
How stuff is too stiff? It's still manageable
Old 05-22-2013, 07:49 PM   #13
How stiff is too stiff?
Old 05-23-2013, 04:55 AM   #14
When you put your foot on it should go to where it's about to engage with just the weight of your foot and slight pressure should engage it what year is your car and how many miles?
Old 05-23-2013, 05:00 AM   #15
wheelman's Avatar
The '05 clutch pedals are long and stiff (TWSS). Try slipping the clutch a little more.
wheelman is offline   Reply With Quote
Old 05-24-2013, 09:32 AM   #16
The issue is that when I slip it the revs bounce around, they go high, then low then high then it usually ends low because I feel bad for my clutch so I just let it go.
Old 05-25-2013, 10:24 PM   #17
Clutches can take a bigger beating than most people think. Mine has 140k on it and it still works perfect.
Old 05-26-2013, 07:14 AM   #18
Yeah they take a beating but if you let it slip to much is going to start slipping when you accelerate because ridding the clutch means the clutch is half engaged and not so its scrapping against the flywheel and leaving a weird film on it after a while I know this because I learned it the hard way at 17
08:55 PM
