Limited slip - Mustang Evolution
Old 05-28-2013, 01:16 PM   #1
Mustangkid34's Avatar
Limited slip
Does anyone know where I could get a limited slip differential on the cheaper side? Any help would be appreciated thanks.
Mustangkid34 is offline   Reply With Quote
Old 05-29-2013, 06:49 AM   #2
crackhutch's Avatar
You may be better off finding a junked GT and ripping off the 8.8 rear end. LSD is expensive and on top of that, if you're tearing through the rear end you might as well change gear ratios. I haven't upgraded my rear end because I'm waiting to return to the states and find a GT rear end. You can get one from a junkyard for cheaper than a new LSD for the 7.5.
crackhutch is offline   Reply With Quote
Old 08-19-2013, 03:04 PM   #3
07 S197's Avatar
Is that a direct bolt up to the v6?
07 S197 is offline   Reply With Quote
Old 08-19-2013, 04:03 PM   #4
twk
twk's Avatar
Yep. A GT from 2005 to 2010 will fit on your S197. Direct bolt in.
twk is offline   Reply With Quote
Old 08-19-2013, 04:46 PM   #5
07 S197's Avatar
Ok nice to know!!👍
Old 08-19-2013, 08:11 PM   #6
JimC's Avatar
Cheaper in the long run to just swap to an 8.8. If the rear end comes from a 2005-10 then you need to change the pinion flange to mate up to the V6 driveshaft but other than that it is a direct swap.
If you can find a 2011+ rear end, it is a direct swap and should have the correct flange for the 2005-10 V6 driveshaft already.
JimC is offline   Reply With Quote
Old 08-20-2013, 02:17 PM   #7
Bschmidty's Avatar
Don't you need a cobra flange also?
Bschmidty is offline   Reply With Quote
Old 08-20-2013, 04:42 PM   #8
JimC's Avatar
Yes, as I said right above you - 2005-10 you need the flange.
But if you get a rear end from a 2011+ then there is no flange swap needed and it is a direct bolt in.
Old 04-23-2014, 12:29 AM   #9
TTmustang10's Avatar
AM has 8.8 fully built with option for flange direct swap for 7.5 to 8.8 if any serious mods intended for future.
TTmustang10 is offline   Reply With Quote
04:41 AM
