Water - Mustang Evolution
Old 06-08-2013, 06:19 AM   #1
Mustangkid34's Avatar
Water
So I walked out to my car this morning and the drivers side door is filled with water!! Idk how it got filled but is their a drain that may have been clogged or something that isn't allowing the water to escape?? If any one knows how I can get the water out in the first place please help!!
Mustangkid34 is offline   Reply With Quote
Old 06-08-2013, 07:11 AM   #2
shunc01's Avatar
There is plug on the passenger side when you open the hood, just stick you hand in there and clear all the debris inside the cowl. You should be all set..
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 06-08-2013, 09:18 AM   #3
Ya I do that come spring every year but the water is in the drivers side door. I did notice the molding that touches the glass on the door is touching on the passengers side which has no water but has a gap on the drivers door which has the water idk if that would be it or not
Old 06-08-2013, 10:39 AM   #4
shunc01's Avatar
I think you just found your problem.. I would say a good sealant would help it.. Good luck kid.
Mods:
Old 06-09-2013, 10:47 PM   #5
It could be the window molding. Ford even said it in their TSB about a water leak.http://www.justanswer.com/uploads/mu...14152_1121.pdf
ThatsCoolBro is offline   Reply With Quote
Old 06-11-2013, 04:32 AM   #6
KiltedV6Pony's Avatar
I know this is a common problem for 05-09 on the passenger side seeing as how they put in a tiny *** rubber gasket on the passenger side cowl, this happened to me last year bad enough I had to remove my carpet and dry it outside and clean it.
I check the rubber gasket every 4-6 months but apparently it clogged in 2 months since my car took on water last night driving to work.
Im not sure if there is a gasket on the drivers side (I'll be checking later when I replace my filter...again) but I will let you know for sure once I get home from work. But I'll also be removing the gasket as it doesn't seem to have a ::significant:: purpose.
The gasket and picture with my hand is last night.
The carpet with standing water is from last year.
ID:	113526   Click image for larger version
KiltedV6Pony is offline   Reply With Quote
Old 06-12-2013, 02:44 PM   #7
That happened to me about a month ago because that same reason my whole passenger side was filler with an inch or two of water
09:25 AM
