HELP! Loud squeaking!!! - Mustang Evolution
Old 06-18-2013, 08:24 PM   #1
Joe_Roma5's Avatar
I can hear noticeable squeaking coming from the rear and i have no clue what it is. Very annoying, and makes my car sound like poop. I did notice it when i rock back and forth as well. Any suggestions would be great
'06 4.0 V6 custom x pipes, cai, screamin demon coil pack, 10mm live wires spark plug wires, NGK iridium plugs, 93 octane bama tune
Joe_Roma5 is offline   Reply With Quote
Old 06-18-2013, 10:08 PM   #2
Terminator's Avatar
Anything you've done to ur car most recently
Terminator is offline   Reply With Quote
Old 06-18-2013, 10:18 PM   #3
Zhim's Avatar
I got that too. Squeaks when going over speed bumps and shifting. Started noticing it after I upgraded my springs and struts to ford racing ones. don't think anything's loose, so probably bushings wearing out?
Zhim is offline   Reply With Quote
Old 06-18-2013, 11:49 PM   #4
Joe_Roma5's Avatar
Only thing i have done back there is cat back exhaust
Old 06-19-2013, 10:36 AM   #5
grbird88's Avatar
I have the same issue too. It appears to be the bushing on sway bar, etc. I sprayed all of the rubber bushings in the rear with silcone. That seems to have help stop the noise. I have done it a couple of times in the last year and have not had the problem for 6 or 7 months. Good luck
grbird88 is offline   Reply With Quote
Old 06-19-2013, 10:48 AM   #6
Zhim's Avatar
Well then, time for sway bar upgrades lol
Old 06-21-2013, 04:29 PM   #7
Stratstang's Avatar
I have the same issue. It's the lca's on my car. Liberally spraying WD40 or silicone spray helps as a temp fix, but really they need to be replaced.
Stratstang is offline   Reply With Quote
Old 06-24-2013, 02:08 PM   #8
Had this for awhile on my old 94 V6, but was coming from the front. Ball joint went kaboom.
Scoobuh is offline   Reply With Quote
Old 06-24-2013, 02:26 PM   #9
Joe_Roma5's Avatar
Im getting so many different answers! And still no clue what it is! Shocks? Sway bar? Ball joint? Control arms?!?
Old 06-24-2013, 04:27 PM   #10
Stratstang's Avatar
The cheap way to find out is to lube the lca's, then the sway bar and so on until you stop the squeak. It'll just cost you a can of silicone spray. Then fix the problem properly. I had a ball joint go on my '09. It didn't squeak at all, but made a clunk when going over bumps, like driveways etc.
07:00 PM
