Headlight blackout covers - Mustang Evolution
Old 06-20-2013, 10:28 AM   #1
Bigkat122's Avatar
So I bought the blackout covers from AM and installed them this weekend. I do not have HIDs, just the stock halogens. I couldn't see more than like 10 feet in front if me at night. So I replaced the bulbs with new Silverstar zXe High Performance Halogens. I swear, they didn't make a bit of difference. The covers give my car such a mean look, I dont want to take them off. Anyone got any ideas?
Bigkat122 is offline   Reply With Quote
Old 06-20-2013, 10:50 AM   #2
94CobraUSMC's Avatar
Are they just the ones you snap on? If so just take them off at night
94CobraUSMC is offline   Reply With Quote
Old 06-20-2013, 10:54 AM   #3
Nobody sees your tinted headlights at night. Take the stupid covers off at night
Old 06-20-2013, 11:01 AM   #4
they do look good, theres really only two options
A - listen to the others & take them off at night
or
B - get HIDs
Old 06-20-2013, 11:12 AM   #5
Originally Posted by silverskoundrel
they do look good, theres really only one option
A - listen to the others & take them off at night.
Fixed.
Old 06-20-2013, 11:17 AM   #6
I just ordered the covers as well but i have the center fogs and they are basically bright enough to drive with, I have the CS fogs also, but the covers look sweet
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-20-2013, 11:24 AM   #7
Fixed.
I posted the just for you cause I knew you were gonna say something about HIDs
Old 06-20-2013, 11:31 AM   #8
Bigkat122's Avatar
I've got daytime running lights, and as far as I know, according to AM, I can't install HIDs bc of that. I've researched trying to disable the DRL and that seems to be near impossible. I guess my only option is to take the dang things off if I'm driving in an area at night that isn't lit well.
Old 06-20-2013, 11:41 AM   #9
get fog lights, not saying they'll solve the problem but they may help some
Old 06-20-2013, 07:51 PM   #10
Replace those cheap "covers" with a pair of smoked headlights! Don't cheap out, you pay for it in the long run (as you can see, literally).
Btw, you're in the 05-09 Mustang section, bro.
Rice Eater is offline   Reply With Quote
Old 06-21-2013, 04:36 PM   #11
Stratstang's Avatar
Safety has to always trump looks. Take them off.
Stratstang is offline   Reply With Quote
Old 06-25-2013, 07:39 PM   #12
dolfin13's Avatar
I have a pair of covers on my headlights. But I have hids on mine so I can see fine at night. I know even though they snap in place. When u take them on and off they get scratched up on top and in the corners. But they do look nice
dolfin13 is offline   Reply With Quote
Old 06-25-2013, 08:10 PM   #13
Gmullinix's Avatar
You can use HIDS even if you have DRL's. you just need to get a relay harness for them and they will work fine.
Gmullinix is offline   Reply With Quote
07:11 AM
