Leaking coolant - Mustang Evolution
Old 07-26-2013, 12:45 PM   #1
Leaking coolant
I have a 2006 mustang and I've been losing coolant out of my thermometer housing. It spurts out when I rev the engine or accelerate fast. I have already replaced the entire housing unit and it started leaking again about 2 weeks later. Any ideas on any sealant, or if I maybe need to get the entire system flushed in case there's a back up?
denises08 is offline   Reply With Quote
Old 07-26-2013, 01:24 PM   #2
08Mustang's Avatar
My thermostat housing started leaking very badly around 61k miles and is a very common issue on the 4.0...I replace my housing and it's still fine 10k miles later so I'm not sure man
08Mustang is offline   Reply With Quote
Old 07-26-2013, 02:16 PM   #3
Billymich's Avatar
Did you use a new gasket? Did you use RTV? if so how much and on what side of the gasket? Was the gasket facing the right direction??
Old 07-26-2013, 06:24 PM   #4
Stratstang's Avatar
Me too, but at around 90K miles. I did the housing, thermostat and a flush and fill at the same time. It's only been about 6 weeks, but so far so good.
---------- Post added at 08:24 PM ---------- Previous post was at 08:20 PM ----------
Did a shop do the work? If so, go back there. They should stand behind their work. Could be something dumb like wrong torque specs or something allowing a gap for coolant to leak from.
Stratstang is offline   Reply With Quote
05:35 PM
