tune up - Mustang Evolution
Old 07-28-2013, 06:29 PM   #1
tune up
I just got my mustang with 50k.. what tune up should I do?? Previous owner said he only did oil changes and air filter
dark2007 is offline   Reply With Quote
Old 07-28-2013, 08:53 PM   #2
Blogger
99ford's Avatar
I'd suggest a fuel induction service, replace the fuel filter, flush brake fluid, and replace the thermostat housing before it explodes! Which means you'll have to flush the coolant.
Its also a good tome to do an oil and filter change. Also inspect the brakes, and suspension composted for wear
That's it they don't need too much and you
may want to change the cabin air filter
And while we're at it Rotate and Balance tires and check your wiper blades it's also a good time to check the alignment and tires.
Old 07-29-2013, 10:04 PM   #3
08Mustang's Avatar
+1000 for the thermostat housing! Like seriously as soon as you can!
08Mustang is offline   Reply With Quote
Old 07-29-2013, 10:45 PM   #4
Jayjay's Avatar
Thermostat is a plus
Check the levels on your transmission make sure they are full
Also check your tie rod ends, mines where completely worn out.
Clean your throttle body
Check brake pats and rotors
And clean your engine good and keep an eye for any oil leaks that need to be corrected
Jayjay is offline   Reply With Quote
Old 07-30-2013, 02:07 AM   #5
Mustang_2005's Avatar
Yeah definitely thermostat housing you don't wanna deal with that if it explodes like mine did.
Mustang_2005 is offline   Reply With Quote
Old 07-30-2013, 08:12 AM   #6
How do I change the thermostat??
Old 07-30-2013, 11:23 AM   #7
Do I just change the thermostat or all with the housing?? Also for the transmission fluid how do I check it
Old 07-30-2013, 01:20 PM   #8
Jayjay's Avatar
The thermostat it's kind of simple, just need some pliers. Remember when you remove the thermostat all the radiator fluid it's coming out too. Put the new one the same way you took out he old one( facing direction). I believe you also need to get any trapped air by tapping on the hoses.
For the transmission oil I took my car in for a multi point inspection that comes included with the oil change. Since my car is a automatic. Automatic cars did not come with a dip stick only the manuals did. Also if the dealer notice it's low they will too it off with fluid with their Check up.
Old 07-30-2013, 03:46 PM   #9
Stratstang's Avatar
No dipstick on the manual trans either. You have to get under the car to check the fluid. At 50k the fluid should still be good depending on driving conditions, but it's still a good idea to check it.
I agree with the thermostat housing. Mine went at 90k miles, but I'm lead to believe that I got more life out of it than most.
Stratstang is offline   Reply With Quote
Old 07-30-2013, 03:47 PM   #10
Yeah I blew mine at 65k.
Old 07-30-2013, 06:05 PM   #11
Kustumb's Avatar
Would this thermostat housing cause your temperature to fluctuate sometimes?
Kustumb is offline   Reply With Quote
Old 07-30-2013, 06:07 PM   #12
Stratstang's Avatar
A bad thermostat would. A bad housing would cause coolant leaks, which would cause temp issues if enough coolant was lost.
Old 07-30-2013, 06:36 PM   #13
Kustumb's Avatar
Hmm. My temp gauge has been going all the way to high like once a week when I'm driving then coming back down 2-3 seconds later
Old 07-30-2013, 06:50 PM   #14
Jayjay's Avatar
Maybe your thermostat is getting stuck
Old 07-30-2013, 07:13 PM   #15
Stratstang's Avatar
Yeah, could be the thermostat. Keep an eye on
your coolant level though.
03:09 AM
