Temperature Problem - Mustang Evolution
Old 08-02-2013, 05:37 PM   #1
Kustumb's Avatar
Temperature Problem
Ok so I focused on the temp gauge for the past week.
Twice this week (while on the highway) the temperature gauge has gone all the way to the red-zone (as in max) and then has gone back down to the middle a few seconds later.
Both times I've been cruising at around 100km/h, so nothing crazy.
You guys have been talking about the thermostat housing but my car is only at 40,000 miles (like 60,000 km).
So I'm thinking of replacing the housing, is there anything else I should replace?
Kustumb is offline   Reply With Quote
Old 08-02-2013, 05:47 PM   #2
Stratstang's Avatar
Replace the thermostat while you're in there. Are you losing coolant? If not the housing is likely fine and only the thermostat might be the problem. My housing bought it at 90,000 km's but I do lots of highway. Had the thermostat done at the same time rather than having to go in twice.
Stratstang is offline   Reply With Quote
Old 08-02-2013, 05:50 PM   #3
Kustumb's Avatar
There is some leakage from here, just around the cap.
Old 08-02-2013, 05:57 PM   #4
Stratstang's Avatar
Hmmm...if that's your only leak then the housing is fine. Likely a thermostat and flush and fill will be good. Sounds like the coolant is boiling over.
---------- Post added at 07:57 PM ---------- Previous post was at 07:55 PM ----------
BTW... Your engine bay looks like you could eat off of it. Nice and clean!
Old 08-02-2013, 06:00 PM   #5
Kustumb's Avatar
Hahah thank you.
And thanks for the info. So, thermostat replace, flush & fill. My stupid hood also has a paint bubble which means I'll have to replace it soon-ish.
Costs are adding up :{
Old 08-02-2013, 06:13 PM   #6
Stratstang's Avatar
My hood had several paint bubbles on the inside at the front. When I took the paint off the metal was fine, so I just painted over it. Yeah, with cars costs do add up! I don't mind the cost of mods, it's the repairs that bug me!!
Old 08-02-2013, 06:15 PM   #7
Kustumb's Avatar
+1. Plus I want to get a Cobra or a Ram hood anyways. Not sure which[ATTACH]Click image for larger version
Old 08-02-2013, 06:19 PM   #8
Stratstang's Avatar
I was looking at hoods on AM. Cirvini makes a really nice ram air with an optional ram air fitting to the air box. About $1,000 for both unpainted. It sounds expensive but a stock Ford hood is around $800, so it's not that bad. Plus it'll never rust!
Old 08-02-2013, 06:22 PM   #9
Kustumb's Avatar
Right and right. I would rather get mine painted from Cervinis tho. Pretty sure the shops around here cut corners whenever they can. Sucks that AM can't paint hoods.
And you mean this? Cervini's Mustang Concept Hood - Unpainted (05-09) 1176 - Free Shipping!
It's pretty nice, but too similar to our stock hoods in my opinion. Need some height to it!
Old 08-02-2013, 06:30 PM   #10
Stratstang's Avatar
Yeah, that's the one. I see what you mean about the similarities. I agree about the paint too. It's tough to find a good shop.
Old 08-02-2013, 06:31 PM   #11
Kustumb's Avatar
In any case. I'm trying to not drop too much money on the V6 until I can pick-up a GT. Then the REAL FUN begins.
Old 08-02-2013, 06:34 PM   #12
Stratstang's Avatar
Oh man yes!!
Old 08-02-2013, 09:02 PM   #13
08Mustang's Avatar
Still got 4 more years with mine til after college!
08Mustang is offline   Reply With Quote
Old 08-02-2013, 09:13 PM   #14
Billymich's Avatar
Have you lost any coolant? It may not hurt to verify head gasket integrity
Old 08-03-2013, 01:30 AM   #15
Kustumb's Avatar
Well as I stated above its leaking a little. It might be boiling over. There's some dried coolant around the cap.
Old 08-09-2013, 10:56 AM   #16
Audicrashdummy's Avatar
I would still do the housing even if thats not the problem right now.. its a cheap product that they decided to make out of plastic and then put directly on the engine. Try look under your intake manifold and see if theres coolant there. If there is its the housing thats how I found mine.
Audicrashdummy is offline   Reply With Quote
Old 08-18-2013, 01:25 PM   #17
Kustumb's Avatar
Ok this time it was on max long enough to get the light on >.< The garage will be replacing it this wednesday
Old 08-19-2013, 02:55 PM   #18
07 S197's Avatar
The ford hood won't rust either it's aluminum.
07 S197 is offline   Reply With Quote
Old 08-19-2013, 02:58 PM   #19
Stratstang's Avatar
Good to know!
Old 08-19-2013, 05:15 PM   #20
Kustumb's Avatar
So this just happened. Any ideas?
Old 08-19-2013, 05:16 PM   #21
Kustumb's Avatar
Old 08-19-2013, 05:38 PM   #22
Stratstang's Avatar
I googled images of dried coolant on the engine and got this:
Maybe your cap is toast.
Old 08-19-2013, 06:40 PM   #23
Kustumb's Avatar
Thanks man. Maybe. It's never been like this. I think it's definitely related to the heat problem I've been having. Last night the high temp light came on, it's was that hot for a couple of seconds
Old 08-19-2013, 07:10 PM   #24
67Stanger09's Avatar
Hey I have around 45000 miles on my 09 v6 and had to replace my thermostat housing and haven't had any problems since!!
67Stanger09 is offline   Reply With Quote
Old 08-19-2013, 08:20 PM   #25
Stratstang's Avatar
Hey anytime. I'm just guessing it's the cap as the spray seems to radiate out from there. Look at your fuse box on the left of the picture.
There's very little castoff in front of the cap, as if it happened at speed and was forced back toward the firewall.
Old 08-20-2013, 08:55 AM   #26
Are you sure you coolant is diluted right?
Old 08-20-2013, 11:08 PM   #27
Kustumb's Avatar
Correcto. It's being checked out tomorrow morning. Will keep you posted. My engine bay is so ****ing dirty
Old 08-21-2013, 03:31 PM   #28
Kustumb's Avatar
Replaced rad cap and topped up coolant. Hopefullyl it's gone now apparently the car has two thermostats, which one should I replace?
Old 08-21-2013, 04:08 PM   #29
Stratstang's Avatar
Hmmm...everything that I've read has no mention of two thermostats.
Found this. Only mentions one.
Old 08-21-2013, 04:51 PM   #30
There's only one...
Old 09-08-2013, 07:13 PM   #31
Kustumb's Avatar
Sorry for bumping this, I just wanted to give you guys an update. We replaced to rad cap the last time I went to the shop and they flushed my coolant. I didn't receive an increase in temperature for about 2-3 weeks until today and decided to check under the hood one more time.
It is leaking once again. Now you guys told me to replace to entire housing itself, so I'm going to do just that in a few days.
Old 09-08-2013, 08:59 PM   #32
Where is it leaking? Is it dripping down to steering rack? That's hoe I noticed mine then I looked under intake manifold and it was a lake of coolant
Old 09-08-2013, 09:04 PM   #33
Kustumb's Avatar
It seems to be leaking out of the rad cap and there is sprayed coolant all over the top of the engine compartment.
Something like the attached (its not my engine).Click image for larger version
Old 09-08-2013, 09:09 PM   #34
Definitely replace your thrmostat. I would say its your thermostat not closing to let the coolant cool and its just circulating to quick and overheating
Old 09-08-2013, 09:14 PM   #35
Kustumb's Avatar
I'm thinking I should do the housing as well while I'm at it? Do you have any ideas on the cost I'm looking at? I'm sure I'll find out tomorrow but it'd be nice to have an estimate to compare it to. I checked out another website and they said over $400?
11:51 PM
