vibration problem - Mustang Evolution
Old 08-05-2013, 08:27 AM   #1
jek57's Avatar
vibration problem
Hi all i have a 09 v6 that just started to vibrating if i go over 80 mph...it feels like the feeling when u go over rumble strips but the front end doesnt shake not sure where to start looking ..any ideas?
jek57 is offline   Reply With Quote
Old 08-05-2013, 08:37 AM   #2
BeachMonkey100's Avatar
Check alignment, tie rod ends, possibly a loose wheel? are the factory retaining clips still on the rotors? that's all I can come up with off the top of my head.
2006 Mustang GT Premium Satin Silver Metallic | 5 Speed Manual | Hurst Short Shifter | K&N CAI | JSR Strut Brace, FLCA Brace, Rear Shock Tower Brace | Flowmaster Axle Backs | Ford K Springs | JM Trackbar | 93 Bama Performance Tune
BeachMonkey100 is offline   Reply With Quote
Old 08-05-2013, 08:46 AM   #3
jek57's Avatar
ill start there almost feel like a bad tire ..i was just thinkin about the drive shaft do they go bad like the bearings or something? the car is all stock
Old 08-05-2013, 08:57 AM   #4
it could be a lost wheel weight too, it will cause the same situation but not near what you're talking about. usually a drive shaft doesn't go bad unless you break it lol. No bearings just u-joints. For peace of mind you could check it but if it were that you would feel it well before 80mph
Old 08-05-2013, 10:09 AM   #5
jek57's Avatar
Thanks for your help im going to check the tires..balance it fine at lower speeds just when i got past the 80 mark does it start
Old 08-05-2013, 11:11 AM   #6
Yeah for sure! be sure to check the other things too, hopefully you'll find whatever it was!
Old 08-06-2013, 07:23 PM   #7
Whitestang23's Avatar
I have the same problem but when I go about 70-80 mph once I go 80 it stops,
Whitestang23 is offline   Reply With Quote
Old 08-06-2013, 08:20 PM   #8
Jayjay's Avatar
I'll get wheel balance first,
Jayjay is offline   Reply With Quote
Old 08-07-2013, 05:21 AM   #9
jek57's Avatar
Yea im going to try that first ..i had it in for a tran fluid change they checked it out they said it might be the driveshaft but they weren't sure. so for now ill keep it under 80..
Old 08-09-2013, 10:48 AM   #10
Audicrashdummy's Avatar
I have the same problem. Do you have anything other than factory parts on yours?
Audicrashdummy is offline   Reply With Quote
Old 08-09-2013, 05:37 PM   #11
No everything is stock except the wheels but the problem was there before I changed them, continued after I changed them.
Old 08-09-2013, 06:07 PM   #12
Okay well ive heard that it could be the control arm bushings there next in my list with wheels
Old 08-10-2013, 08:47 AM   #13
Mechanic said the same thing but i haven't really checked it out, let me know if it is that the problem.I've also had this squeak when I hit bumps or on take off. It's from a part that's on the driver side right between the back wheel and driver door. Not sure what its called but I've used wd40 on it and it stopped the squeaking and reduced the vibration.
Old 08-10-2013, 02:59 PM   #14
Stratstang's Avatar
The squeak is probably the lca's. Very common. I just bought Ford Racing replacements from AM to solve that problem. I did the WD40 thing for a while. It eventually stops working.
Stratstang is offline   Reply With Quote
Old 08-12-2013, 06:50 PM   #15
jek57's Avatar
Going to take the driveshaft out tomorow and going to take to a drive shaft place they can check it to see if is in balance ..ill let u know how i make out ...i got on the net and the symptoms that they discribed so just like mine does..so ill find out
Old 09-10-2013, 05:57 PM   #16
Any update on the shaft? Or was anything els causing that vibration. Have somewhat of the same problem so it would help with anything you know.
Old 09-10-2013, 07:10 PM   #17
It cpuld be the u joint in the drive shaft. Is it just the shifter shaking a lot?
Old 09-10-2013, 08:03 PM   #18
No I have an automatic there's just this vibration that I feel through the front of the car and on the steering wheel when I go 60-80 mph. Once I go past 80mph the vibration stops
Old 09-10-2013, 09:01 PM   #19
Same problem I have. No clue why
Old 09-11-2013, 05:38 AM   #20
It's getting really harder to ignore because I drive to work every night at 70mph an I can just feel the vibrations throughout the trip 😒
Old 09-11-2013, 06:31 AM   #21
tc x 4's Avatar
With it going away past 80 leads me to believe it's an alignment issue.
Old 09-11-2013, 01:01 PM   #22
Jayjay's Avatar
Same here it sounds alot like a wheel is not balance right.... Also are your tires facing the right direction... Take it to a reputable tire shop and have them balance your tires. They will also check that your tires are put on the right direction. And If possible get an alignment too.
Old 09-11-2013, 04:22 PM   #23
Tires seem to be facing the right way but ill take it to get them balanced and get an alignment as well. I just bought the wheels the guy from Craigslist that sold them to me said they were balanced but the vibration was there when I had the stock wheels and I had them balanced.
Old 09-30-2013, 05:48 PM   #24
jek57's Avatar
Just a update i took it to the dealer they looked at the driveshaft and said it looked ok so i had them rotate the tires and spin balanced them does seem smoother back but it still get noisy and some vibrating the 85 plus said the ball joint were starting to get loose also that might have something to do with it also..they wanted like 800.00 to do them lol ..right
Old 09-30-2013, 06:36 PM   #25
thats ridiculous
Old 04-06-2015, 07:05 PM   #26
ON my vehicle I the steering wheel and so forth shakes when I am traveling around 70-75 mph...
dtreida11 is offline   Reply With Quote
Old 04-27-2015, 06:41 AM   #27
Bdawg's Avatar
Probably need new struts
Bdawg is offline   Reply With Quote
Old 04-27-2015, 03:33 PM   #28
I hope you are right... I ordered some a few weeks ago but they are on backorder...
05:43 PM
