Help with coil - Mustang Evolution
Old 08-16-2013, 11:33 PM   #1
Vicello93's Avatar
Help with coil
Hey everyone, so today I got a screaming demon could and Taylor wires, I installed them on my car and it's running like crap.. Misfiring a lot, I drove around to see if the car's computer needed to learn something but still misfiring, when I'm I'm a steady speed it's fine but accelerating and idle it's bad... Any thoughts? Thanks in advance!
Vicello93 is offline   Reply With Quote
Old 08-16-2013, 11:35 PM   #2
1slosix's Avatar
well screamin deamon coils are commonly known for being junk at least for 94-04 models...wouldn't surprise me if they are for s197s as well.
carving corners like a boss
Old 08-16-2013, 11:42 PM   #3
Vicello93's Avatar
Oh great:/ well I might as well just return them.. And get a good one
Old 08-16-2013, 11:53 PM   #4
1slosix's Avatar
msd makes a quality coil
Old 08-17-2013, 12:05 AM   #5
Vicello93's Avatar
Yeah I was thinking about getting one of those if it doesn't work out.. I just contacted AM to see if they can help me out or if I can return or exchange
Old 08-17-2013, 12:10 AM   #6
1slosix's Avatar
sounds good...i hope things work out keep us updated.
Old 08-17-2013, 12:54 AM   #7
Vicello93's Avatar
Sure will! Thank man
Old 08-17-2013, 06:48 AM   #8
seems like knowing that before ordering would've helped :\
Old 08-17-2013, 07:05 AM   #9
Vicello93's Avatar
I read reviews about it and I heard good and bad things, but I wanted to try it and see if it works or not, well i guess it doesn't ..( I know dumb idea) But I'm sure it's something wrong with the coil, Am might be able to help me out ( I hope)
Old 08-17-2013, 07:12 AM   #10
I don't see AM not helping!!
Old 08-17-2013, 07:47 AM   #11
Stratstang's Avatar
I've had a Screaming' Demon coil for over a year now. No problems. I've put around 20K miles on it. I kept (and still have) the stock coil just in case.
I guess that I'm one of lucky ones. I had read many good reviews and very few bad ones. Did you use the provided dielectric grease before putting the wires on the coil pack?
Stratstang is offline   Reply With Quote
Old 08-17-2013, 08:16 AM   #12
Vicello93's Avatar
That's good to hear! Yes I used the grease, I just swapped out the SD and put the stock back and I'm waiting for an email from AM.
---------- Post added at 08:16 AM ---------- Previous post was at 08:16 AM ----------
Yeah they r really good with customer service
Old 08-17-2013, 08:17 AM   #13
hallelujah!!
Old 08-17-2013, 11:31 AM   #14
Vicello93's Avatar
hallelujah!!
Haha lol
---------- Post added at 11:31 AM ---------- Previous post was at 11:29 AM ----------
So I put all the stock coil and wires back and it's still bad.. Now I just had a new fuel pump put in, could it be it? Fuel pressure?
Old 08-17-2013, 02:33 PM   #15
Stratstang's Avatar
Haha lol
I wouldn't think so. Are you sure you got the wires properly seated and in the right order? The firing order isn't a straight 1 through 6. I think it's more like 1,2,3,4,6,5. Someone can correct me if I'm wrong.
Old 08-17-2013, 02:46 PM   #16
Vicello93's Avatar
Yeah I connected them right, and plugged them nicely, and it's back firing too. It runs ok when at steady speeds but if u tap te had a little it starts
Old 08-17-2013, 04:38 PM   #17
kf4myo's Avatar
You may have a plug wire that pulled apart on you
kf4myo is offline   Reply With Quote
Old 08-17-2013, 04:44 PM   #18
Stratstang's Avatar
+1.
Old 08-17-2013, 05:43 PM   #19
Vicello93's Avatar
Ahhh ok ill check thanks
---------- Post added at 05:43 PM ---------- Previous post was at 05:40 PM ----------
Aahh ok Ill check. Btw the grease that comes with the wires, do I put them on the metal or the rubber that goes in the coil?
Old 08-17-2013, 05:55 PM   #20
Vicello93's Avatar
Old 08-17-2013, 06:15 PM   #21
kf4myo's Avatar
Goes on the metal. It keeps the two surfaces from welding together and from corrosion
Old 08-17-2013, 07:11 PM   #22
Vicello93's Avatar
Oh ok , maybe that's the problem? I put on the rubber..
Old 08-17-2013, 08:06 PM   #23
kf4myo's Avatar
It should run even if you didn't put the dielectric grease on the metal part
Old 08-17-2013, 09:08 PM   #24
Vicello93's Avatar
So I checked everything again and it's all in the right place.. Monday it's going to the shop.. I got like give codes and engine light blinking . Thanks everyone for the help! Ill keep posted on what's going on
Old 08-19-2013, 11:16 AM   #25
Vicello93's Avatar
I found out the problem! One spark plug was cracked so I replaced it and it's good to go
Old 08-19-2013, 01:29 PM   #26
Stratstang's Avatar
Great news! Sounds like a cheap fix too!
Old 08-19-2013, 02:39 PM   #27
Vicello93's Avatar
Yup! The mechanic is a friend of mine so he just changed one that was cracked, and he recommended me to get Ngk iridium plugs. So back to AM lol I need plugs anyway so better do it right
Old 08-19-2013, 02:41 PM   #28
Stratstang's Avatar
A friend who is also a mechanic is like gold!
Old 08-19-2013, 02:49 PM   #29
Vicello93's Avatar
Oh yeah! And he has a 03 gt, so he's also a mustang guy
07:30 AM
