Revving in nuetral - Mustang Evolution
Old 08-23-2013, 08:40 AM   #1
Region: South Dakota
Revving in nuetral
I've been having an odd issue since I got my car (5 months ago) where if I put my car in neutral while the car is moving and leave the clutch engaged it will just start revving up (pretty high, but at a steady pace) until I come to a stop. I have been treating this issue by rolling to stops with the clutch disengaged, which completely nullifies the issue, but I was recently informed that this stresses the TOB, and it's not good to do this, so I figured I would see if anyone has any ideas what might cause this?
Remember that this only happens while the car is moving, I can sit still in neutral all day and it idles perfect, so I don't see how it could be a vacuum line or IAC or TPS?
Thanks in advance guys and gals!
Combatman is offline   Reply With Quote
Old 08-23-2013, 03:34 PM   #2
Stratstang's Avatar
It could be the throttle stop screw. I have read in other forums that people who don't know any better adjust them to compensate for another issue.
Stratstang is offline   Reply With Quote
Old 08-23-2013, 03:48 PM   #3
Loc: Austin,TX
Why would you coming to a rolling stop with the clutch engaged anyways? Just a question,not trying to bash.
Old 08-23-2013, 05:02 PM   #4
It's come to a stop with the clutch engaged to take stress off my throw out bearing, and my left calf.
And whereabouts would I look for the aforementioned idle screw?
Old 08-23-2013, 05:04 PM   #5
Ubnbit's Avatar
I think the terms are just reversed. Engaged meaning in gear, disengaged meaning the car is not in gear.
Old 08-23-2013, 05:09 PM   #6
Stratstang's Avatar
Looking toward the front of your car, it is contained in the drive by wire case attached to the left side of the throttle body. When removing it to get to the screw, be careful as the butterfly spring is in there. You will have to put the spring back with tension or the butterfly won't work. It's a bit tricky but not too bad. Also, be careful with the case screws on removal, they are easily damaged.
Old 08-23-2013, 05:10 PM   #7
Yes sir, i meant the clutch is engaged (meaning my food is off it) but the car is in Neutral, so the engagement of the clutch should have no effect on the engine, but for some reason mine still makes my engine rev while the car is rolling in neutral.
Old 08-23-2013, 05:27 PM   #8
Alright, and how do I know if it needs to be adjusted?
Old 08-23-2013, 05:43 PM   #9
Stratstang's Avatar
What rpm's does your car rev at idle when warmed up?
Old 08-23-2013, 05:50 PM   #10
750ish
Old 08-23-2013, 06:11 PM   #11
Stratstang's Avatar
750ish
That's acceptable. I thought that it might have been high if someone had played with it, though idle is computer controlled. I'm assuming that you don't have a check engine light. I read a similar issue to yours where the car was fine at idle, but that the rpm's soared at speed when in neutral. He had gotten the car used and didn't know it's history. Backing off the throttle screw solved his problem. Problem is you won't know if it needs adjusting until you're in there. The butterfly gear should sit firmly against the screw, but there shouldn't be much of the screw exposed.
There is an adjustment screw on the bottom rear of the case, accessible without removing anything. You could try backing that off before taking anything apart, but only very incrementally as you won't be able to see the contact between the screw and the gear inside the case.
Old 08-28-2013, 12:19 PM   #12
Alright so I just got time to look at it today, and im looking at the case here and I'm not sure with screw you are referring to, you have me worried about taking the case off as I'm not sure exactly what you mean about tensioning the spring till I take it apart. Any words of advice before I start digging into the intricacies known as the drive by wire system?
Old 08-28-2013, 05:27 PM   #13
Stratstang's Avatar
Okay, I've been researching this more as the last thing I want to do is to steer you wrong. I've had my TB drive by wire apart several times with no issues, but have never had to adjust the set screw. I have been reading today that adjusting it could alter the voltage for proper EFI operation, so unless you have a meter and know the parameters of where it should be, you could be in for an issue more than what you have. I found this info on another forum and I cannot vouch for its reliability.
I certainly don't want to waste your time, but I am inexperienced when it comes to voltage parameters and I don't want to cause you grief. Sometimes an experienced shop is your best friend, particularly if it prevents you from making things worse. I'd really like to hear how you make out.
05:06 PM
