(NOT A MUSTANG) What is this wire?! - Mustang Evolution
Old 08-29-2013, 05:40 PM   #1
qccoles's Avatar
Probably the wrong section, move if necessary, but since hyundai forums aren't very active and and I have an s197, I figured...
This is on my 2001 santa fe. This is a picture of the front passenger wheel. I have the ABS and TCS lights on. I went under it and noticed that this exact wire is frayed and disconnected on the front driver side.
Does anyone know what this might be?
qccoles is offline   Reply With Quote
Old 08-29-2013, 05:52 PM   #2
Stratstang's Avatar
This might help. Apparently tone ring failure is common on Sante Fes and causes similar issues as yours.
http://www.hyundaiforum.com/forum/hy...ame-time-8238/
Stratstang is offline   Reply With Quote
Old 08-29-2013, 06:03 PM   #3
qccoles's Avatar
I did a little research on it but the tone rings are all i've come up with, I've traced the wire up to the engine bay and it goes to a tiny connector, less than an inch tall/wide. It has to some type of sensor. I'm guessing the wheel speed sensor.
Old 08-29-2013, 06:05 PM   #4
Stratstang's Avatar
That would be my guess too.
Old 08-29-2013, 06:38 PM   #5
TheBandit's Avatar
It is your wheel speed sensor or abs sensor that the TCS uses also.. You have found your problem with the frayed and disconnected one. It will cause all of those lights to light up like a Christmas tree.
TheBandit is offline   Reply With Quote
Old 08-29-2013, 06:43 PM   #6
qccoles's Avatar
I actually left and went to autozone to compare it to a wheel speed sensor, I was right! Thank you, though. Glad to know this should turn the lights off.
Old 08-29-2013, 06:45 PM   #7
Stratstang's Avatar
That's great, good luck!
Old 08-29-2013, 06:49 PM   #8
qccoles's Avatar
Sad thing is, this part costs $50 for our mustangs. And the price jumps up to $200 for the santa fe. Needless to say, I've already located a santa fe for parts.
Old 08-29-2013, 07:12 PM   #9
Stratstang's Avatar
Wow, that's quite the premium.
Old 10-14-2013, 03:34 AM   #10
StevensV6's Avatar
Lol 200 dollars to put the Christmas tree up until next Christmas...
StevensV6 is offline   Reply With Quote
04:48 AM
