squeaking between gears - Mustang Evolution
Old 09-01-2013, 05:17 PM   #1
Audicrashdummy's Avatar
So every time I chabge gears a hear a little squeak on the drivers side. I have no clue whqt it is. Anyone have any idea what it is or same problem?
Audicrashdummy is offline   Reply With Quote
Old 09-02-2013, 11:19 AM   #2
Stratstang's Avatar
My clutch pedal used to squeak. Sprayed it with WD40, now no more squeak.
Stratstang is offline   Reply With Quote
Old 09-03-2013, 07:50 AM   #3
Zhim's Avatar
is it when you clutch in? or is it when you let off the gas after hard acceleration? if its when you let off, it might be your suspension.
Zhim is offline   Reply With Quote
Old 09-03-2013, 08:55 AM   #4
Yeah not with clutch. Right after a change gears and I press the gas again it squeaks
Old 09-03-2013, 09:06 AM   #5
Stratstang's Avatar
Sounds like a suspension part. Could be the rear lca, when that squeaks the sound direction is misleading.
Old 09-03-2013, 06:21 PM   #6
What is ica?
Old 09-03-2013, 06:27 PM   #7
Stratstang's Avatar
What is ica?
LCA...stands for lower control arm and is a component of the rear suspension. They are notorious for wearing out and squeaking...loudly. AM has Ford Racing replacements at a very reasonable cost. When mine started to go the squeak was on takeoff or when gassing it after shifting, then after a while it squeaked all of the time.
Old 09-03-2013, 07:07 PM   #8
Oh I know what those are haha. I had no clue wht an ica was. Im replacing front and rear c.a.'s. The ford racing ones.
Old 09-03-2013, 07:25 PM   #9
Stratstang's Avatar
Haha, my fault for not using caps!
Old 09-03-2013, 10:34 PM   #10
Zhim's Avatar
did you get it lowered?
Old 09-04-2013, 04:25 AM   #11
Stratstang's Avatar
No, just replaced the ca's.
Old 09-04-2013, 12:38 PM   #12
Zhim's Avatar
sorry I was referring to op
10:34 PM
