Halp! Halp! - Mustang Evolution
Old 10-02-2013, 04:13 PM   #1
Mkolabin's Avatar
Halp! Halp!
Hi guys, sorry to be away so long.
Life, and all. Five weeks til baby, then dadding it up for life.
Anyway, here's my problem.
It started a few weeks ago with an occasional and very intermittent battery warning. For no reason at all, it would appear, linger for a while and then disappear with no indication of trouble. Then, very occasionally, I'd see the lights dim or the engine idle go up slightly when additional systems were turned on (such as A/C, defrost, etc).
Then, about a week, week and a half ago, it started to occasionally click. It's not the lifters or anything as obvious as that and there seems to be no consistent reason for the tick, but I'm worried it's associated with my fan clicking on, or the alternator but it WON'T do it standing still, so I can't keep my head under the hood to source the noise which again, is just an occasional tick, as if my fan or alternator. And then yesterday, my engine temp gauge went strange... it didn't break, it's still reacting to engine temp, it's just reading really, really low even after it should be well and warmed up but here's the thing - the engine seems to be running along just fine and there's no indication of overheating; no power loss, no heat-stink, nothing.
I haven't had the time to start troubleshooting as my wife is really, very pregnant, but here's what I'm thinking:
Electrical: fuses, hopefully?
Thermostat Housing: Common problem, but I don't know the lead up symptoms.
Fan or Alternator: Clicking "on"?
Cracked block: GOD WHY? WHY GOD?! WHY!?!
Oh, and bee tee dubs it's a 2006 4.0L manual with 70,000 KILOMETERS on the clock.
Please, Evo... HALP ME!
(also note, the car is running fine aside from that tick-on sound but there's nothing that feels mechanically wrong)
2006 V6 - Black on black. Tints, Louvers, Shorty Antenna and BBK CAI. "We're just getting started folks!"
Mkolabin is offline   Reply With Quote
Old 10-02-2013, 04:40 PM   #2
michaelsneal's Avatar
Check your alternator for total power output, might be the regulator starting to go bad, seen this a lot. strange things start to happen , as for your thermostat, it might be stuck open and you would get a low temp reading.
michaelsneal is offline   Reply With Quote
Old 10-02-2013, 04:46 PM   #3
welcome back fella! lol, definitely test alternator & I replaced my thermostat housing at like 40k when it blew up lol
Old 10-02-2013, 05:10 PM   #4
mine was doing that, get a new alternator and you will never see it again
Mustangman705 is offline   Reply With Quote
Old 10-02-2013, 05:27 PM   #5
Mkolabin's Avatar
Oh thank god.
Alternator I can handle and not too expensive. Same for the Thermostat Housing.
I'm just glad no one has said "Water pump" yet.
I'll run an alternator test ASAP.
Old 10-02-2013, 05:37 PM   #6
my water pump makes a damn squealing noise when I start but it goes away within minutes. im pushing that as far as I can lol
Old 10-02-2013, 05:44 PM   #7
Mkolabin's Avatar
While we're here, I have another question:
When I go full lock, left or right, there's a slight groan from the power steering, but only on full lock and even half an inch off of full lock it's no problem. Could this mean I need to do my power steering fluid?
Old 10-02-2013, 11:59 PM   #8
irishn8's Avatar
No, thats normal.
Old 10-03-2013, 01:21 AM   #9
Mkolabin's Avatar
It's not my alternator.
It's my Compressor. It's clicking when it engages.
How ****ed am I?
Old 10-03-2013, 05:03 AM   #10
irishn8's Avatar
Probably not that much, compressors do that when they are low on pressure so u likely have a coolant leak. Just take it to a place that specializes in a/c.
It still sounds like ur alt might have a problem though, with the battery light on and all. It could po
Old 10-03-2013, 07:12 PM   #11
lol ur battery light will only come on if there is a problem with your alternator... it wont even come on for just a low battery..
06:18 PM
