throttle body - Mustang Evolution
Old 10-15-2013, 03:42 PM   #1
throttle body
Am thinking about adding an throttle body and spacer any idea on how much more HP it would add
Also do I need to add headers for this upgrade? Thanks
rajeev2liz is offline   Reply With Quote
Old 10-15-2013, 05:34 PM   #2
.5hp and no.
Old 10-15-2013, 06:09 PM   #3
NewMtang's Avatar
.5hp and no.
That's kinda high, are you sure.....
Old 10-15-2013, 07:41 PM   #4
JimC's Avatar
0.5 is a little high for a spacer - which is a better paper weight than it is a performance item. Think about it, moving the throttle body a half inch is going to accomplish???????
This isn't like a carburetor where moving the carburetor up changes the length of the runner. The fuel is injected in your car into the cylinder and not mixed with air at the carburetor.
You could add a foot of metal between the intake manifold and the throttle body and you won't notice any difference.
JimC is offline   Reply With Quote
Old 10-15-2013, 07:41 PM   #5
Venomouz831's Avatar
I honestly think it adds nothing
)02 Gt, Founder of WE2G
Old 10-15-2013, 09:15 PM   #6
bigmac3's Avatar
+1 ^
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 10-15-2013, 10:06 PM   #7
Kustumb's Avatar
What about a new throttle body itself? The one that's larger than the stock.
Kustumb is offline   Reply With Quote
Old 10-15-2013, 10:35 PM   #8
Zhim's Avatar
I've been confused about this issue. is the part of the intake manifold that mates up with the throttle body the same diameter? because if it is, then upgrading the tb would cause air to flow from larger to smaller diameter which... logically would cause turbulence or flow restriction right?
Zhim is offline   Reply With Quote
Old 10-15-2013, 10:44 PM   #9
Bschmidty's Avatar
Use your money elsewhere. Unless you plan on porting the intake
Bschmidty is offline   Reply With Quote
Old 10-15-2013, 11:43 PM   #10
MidnightBlueGT's Avatar
I felt a good difference from stock to 78mm on my 02 gt guess it's just different for different models. Less worth it if you dont plan on boosting.
Old 10-16-2013, 07:00 AM   #11
It's true I mean it does serve the purpose more like a paper weight I saw American muscle has a big to for about 400.00 but I was just thinking if it's would it when yo think about the HP gain as compared to the price. I have a 07 v6 automatic the only upgrade I got is a CAI any other recommendations on upgrad es
Old 10-16-2013, 10:53 AM   #12
Exhaust
Old 10-16-2013, 10:55 AM   #13
Exhaust I was thinking more of the mid pypes
Old 10-16-2013, 11:04 AM   #14
Yea you can hear headers, midpipe, axle backs
Old 10-18-2013, 06:19 AM   #15
08Mustang's Avatar
Originally Posted by JimC View Post
0.5 is a little high for a spacer - which is a better paper weight than it is a performance item. Think about it, moving the throttle body a half inch is going to accomplish??????? This isn't like a carburetor where moving the carburetor up changes the length of the runner. The fuel is injected in your car into the cylinder and not mixed with air at the carburetor. You could add a foot of metal between the intake manifold and the throttle body and you won't notice any difference.
That's direct injection. Our fuel is mixed in the intake port just before the intake valve....and I've got a spacer and the only things you'll notice are mainly a cool sound and a little more responsiveness from the throttle but not really any power
08Mustang is offline   Reply With Quote
Old 10-18-2013, 08:54 AM   #16
Audicrashdummy's Avatar
Watch what tb and spacer you get if you do decide. Bigger tb with a stock sized spacer hurts proformance more than anything. For that kinda of mondley just spend a little more and do tge pypes midmuffler exaust. So much more worth it
Audicrashdummy is offline   Reply With Quote
Old 10-18-2013, 08:57 AM   #17
08Mustang's Avatar
Completely!
Old 10-18-2013, 04:09 PM   #18
Idk about you guys but when I installed my 75mm tb and plenum I noticed that I had a lot better throttle response.
I don't think it adds hp though.
I bought them on my quest for full bolt ons yay!
---------- Post added at 03:09 PM ---------- Previous post was at 03:08 PM ----------
Btw I also got a tune for them also
I was under the impression my car would run like garbage without it
KoolPwny is offline   Reply With Quote
06:19 AM
